This is a list of items I sent to Restoration Specialties. The item were mostly in reusible condition. The parts were remove from a '66 D 100. I did this to preserve the parts.
1. cowl drain flap. received, looks correct.
2. vent air flow flap.
3. parking brake cable grommet @ firewall.
4. cab to fender seal.
5. choke cabel/ oil pressure grommet.
6. hood to fender bumpers. received, looks correct.
7. door jam bumpers. received, different but should work.
8. tailgate strut bumper. received, looks correct.
9. fuel sending unit wire through floor.
10. hole edge protector A pillar for dome light.
11. in cab fuel tank isolator pads. received, looks correct.
12. window crank/ door handle washers. received, looks correct.
13. glove box bumpers.
14. ashtray bumpers.
15. radiator top flap seal. received, looks correct cut to fit.
16. front splash gard around shock. received, looks correct.did not receive clips. was there one on each side or only on right?
17. battery tray spacer.
18. door to window frame rubber spacer.
19. 4 speed shifter boot.
20. clutch fork boot. avilable from Dave C. index page jobrated.
21. steering column floor seal. received, looks correct.
22. Radiator core support, front cab mounts. received, looks correct.
23. rear cab mounts. molds made, to poor this week.
24. wiper motor seal. mine was in very bad shape. may need a better one to use as templet.
25. front turn signal lens seal, screws, screw clip nuts.
26. tail light lens seal, screws, screw clip nuts.
27. washer pump.
28. washer bag.
29. washer squirter
30. grommet washer pump hose through inner fender. received, looks correct.
31. brake/clutch master cylinder to fire wall gaskets.
32. '65.5-'68 grill screws, plastic insert nuts, and plastic insert spacer nuts. received, looks correct.
33. clutch/brake pedel pads.
34. heater core through fire wall grommets. received, looks correct.
35. heater box to firewall isolator/seal.
36. floor mat hanger. received, looks correct.
37. NP 435 shifter dust boot. avilable from Dave C. index page jobrated.
38. slave cylinder dust boot. avilable with rebuild kits and replacement cylinder.
If avialible Restoration Specialties don't do. I will keep updated as I receive more parts. I will not be able to test fit many parts as I'm in the process of replacing my cab.
Bumpers, Seals, Grommets, and other items
- City: Hammond, IN
Re: Bumpers, Seals, Grommets, and other items
This should help a lot of people out if they need any of this stuff.
- reallylongnickname
- City: Ottawa, Ontario
To clarify, These are the seals etc that you sent in so they can reproduce and make available for sale to others?
- City: Eagle Point
I'd be interested!reallylongnickname wrote: ↑Sat Mar 03, 2018 8:43 amTo clarify, These are the seals etc that you sent in so they can reproduce and make available for sale to others?
- City: Niagara, ON
This would be great if they could reproduce them.
Does anyone have a picture of item #35, the heater box to firewall isolator? Mine must be missing as my heater box makes a hell of a noise every time I go over a bump, but not sure where it goes or what it should look like. I assumed something was missing. Thanks.
