Door interchangablility
Which doors are swappable? I know that 61-66 are the same. But what about the '67 door compared to '68-71? Is the '67 door a one year door because of the pull-handle inside, and push button outside? I found a local guy on craigslist that has a rust free '69 door, but I dont know if that will work with my '67?
1974 Dodge D600 318 5+2
2003 Ram 2500 Cummins HO
Re: Door interchangablility
steven wrote:Which doors are swappable? I know that 61-66 are the same. But what about the '67 door compared to '68-71? Is the '67 door a one year door because of the twist-handle inside, and push button outside? I found a local guy on craigslist that has a rust free '69 door, but I dont know if that will work with my '67?
- RussRoth
- City: Vancouver, WA
If I remember right you can use the later door on your '67 and keep the same inside door handle by changing your stuff from your '67 door into the later ones. I think it has all the necessary brackets and screw holes to do that. I kept the later style insides on my doors just because I liked them better.
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Thanks Russ, good to hear. As soon as I recoup from buying the electronics for my Hemi, it sounds like that will be next.
Dont know how I quoted myself, I meant to edit, lol.
