fender- 1967 -D-200
Johns67
City: Ashland
State: MT
fender- 1967 -D-200
Post by Johns67 »
On my left side of the truck there is at least a 1/2 inch or better gap between the front fender and the door. The fender seems to be tight and the door just about closes right. When I had the truck painted the gap was painted matellic maroon also. Is it the door that needs to go forward or the fender that needs to go back? Anyone ever have this happen to them?
Thanks!~johns67
Jeffc
Re: fender- 1967 -D-200
Post by Jeffc »
Johns67 wrote:On my left side of the truck there is at least a 1/2 inch or better gap between the front fender and the door. The fender seems to be tight and the door just about closes right. When I had the truck painted the gap was painted matellic maroon also. Is it the door that needs to go forward or the fender that needs to go back? Anyone ever have this happen to them?
Thanks!~johns67
What is the gap at the striker end of the door
and does the rest of the door fit 'fairly" even?
Since the fenders bolt too the fire wall, under
the hood, it's not going to move much to the rear....
but might be able to get a little.
I would say that, unless the door closes perfect,
that is were the adjustment needs to be...
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4sp od
Old iron or no iron!
One size does NOT fit all!
Johns67
City: Ashland
State: MT
thanks!
Post by Johns67 »
I'm going to take out the interior of the cab of my 67-D-200 this summer and paint the inside, then I'll work on trying to line up the doors. Need to get the weather stripping for both doors. The doors close if you slam them, but I know that's not right. When I get ready to do the doors I'm going to visit more. I was told the pins in the hinges will probably need to be replaced. Maybe the gap between the door and the fender on the hinge side will disappear.
Thanks!~johns67- glad it's not the fender.
