Sander
Blue67
Sander
Post by Blue67 »
Plan to do a roller paint job on Old Blue this summer. Can anyone recommend a good sander for body work. Hopefully a one time job so a good one but not body shop quality and pricing please.
Thanks
Blue
tom-adc
City: LaA
Post by tom-adc »
I bought a Craftsman 5" rotary with varible speed control, it uses a hook and loop paper attachment it was a big help to me.
Also if you haven't seen this link it might help with the paint.
http://carpainting.wetpaint.com/page/Ro ... hane+Paint
Jeffc
Re: Sander
Post by Jeffc »
Blue67 wrote:Plan to do a roller paint job on Old Blue this summer. Can anyone recommend a good sander for body work. Hopefully a one time job so a good one but not body shop quality and pricing please.
Thanks
Blue
If you got air, a air board sander is the only
way to go......
cheap throw-away board sanders can be had for
around $30-40 at Harborfreight.
If you think you may be using it more than
just on the one truck/car buy a good one......
square 'palm' sanders can be ok for small areas
and corners, but any large flat panels need a
board sanders to get the 'waves' out......
tom-adc
City: LaA
Post by tom-adc »
I agree with Jeffc on this also, I used the random sander to remove paint in a hurry but when it comes to finishing the longer the better, I used a wooden board maybe 20 inches long I got from harbor freight worked great.
Jeffc
Post by Jeffc »
Nothing wrong with a hand board sander, good workout
if your up to it :Thumbsup
Blue67
thanks
Post by Blue67 »
Tom Good site Thanks. Were you able to wet sand with the orbital?
Jeffc. Are you talking about an electrical board sander? I have only hot air. No air for tools. Not sure my old back will let me do that much sanding by hand.
I expect to end up with a good looking 50 foot paint job as I am not a body and paint man. This is my first try. But it's a working Dodge never a trailer queen.
Thanks
Jeffc
Post by Jeffc »
I have never seen a electrical board sander (there maybe someone making one?) so air and hand are the only
board sanders out there......
Most orb type are also air....
Vibration electrical (palm sanders)
are the main ones out there
and can be used for body work, just not as
effective as the types above for panel work.
Electrical belt sanders and grinder/sanders should not be used for body work, too easy to put cuts in the
surface, then you have to work those out....
If I did not have air, my choice would be a palm
sander and hand board. :2cents
If you ever do buy a compressor, do not buy small,
bigger is better, nothing under 30gal 5hp is worth
s :censored t unless your just using a nail gun.....
and (under 30gal)you will find yourself waiting for the commpressor to 'ketchup' all the time with most air tools....
tom-adc
City: LaA
Post by tom-adc »
No wet sanding with the Craftsman was pretty sure that water and electric tools would not be a good mix :lol:
I was happy with the finish it produced dry but its not good enough to replace wet sanding. My truck was rolled and good 50 feet maybe even 25 feet. :Thumbsup
A440cuda1
City: Cheney
Post by A440cuda1 »
Start with a cheap DA (dual action)sander from harbor frieght(picked up 2 of them, $15 each) and a roll of 80 grit paper, once you have a good cut on the old paint, switch to some 180 grit to knock out most of the sanding scratches. After that you could coat with some rattle can primer and color with what ever you want.
1962 D100 Short bed project
1963 D200 Long bed
1970 D200 Long bed
Many other old rigs, not sweptline related.
A440cuda1
City: Cheney
Post by A440cuda1 »
1963 D200 Long bed
1970 D200 Long bed
