will 68 column work on a 69?
frankyb
Post by frankyb »
I have a 1969 D100 pickup with a slant 6 that is missing the column completely. It used to have a 3 speed shifter on the column as well. I bought the truck this way with the intent to fix it up.
I need a complete steering column with 3 spd shifter on the column and steering wheel.
I understand that a 62, 63 and 64 will not work (different mounting positions, different steering box sizes.
Will a 68 column work on the 69?
Please help.
Thanks, FrankyB
cowboy
Post by cowboy »
I konw the plate that hold's it to the floor is different , might have to rewire it as well , not to sure on the bolt up the rag joint , hold it to it & see , the rest can be made to fit
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
The '69-'71 3spd manual column shifters are the same.
The '61-'68 3spd manual column shifters are different
than the '69-'71 columns.
I suppose with some mods, you could make an earlier
column work for your application. If it were me, I'd
beat the bushes for a '69-'71 column :Thumbsup
frankyb
Post by frankyb »
Thanks John
duracell
City: Peoria,Arizona
Post by duracell »
i put in on the other thread with out knowing more. sucks about the 68 i knew they changed somewhere around there :pale
as always and sometimes not,steve
