How to remove 70 light switch??
Posted: Mon Mar 26, 2007 12:51 am
by nfury8
How does the headlight switch come out on a 70/71? I don't see a set screw on the knob. I know on some of those style switchs the shaft comes out, but I can't figure it out.
Posted: Mon Mar 26, 2007 7:41 am
by 66patrick
Reach around behind the dash. On the switch is a small button. You have to hold this button down and simultaneously pull the shaft out. Once you do that, the switch comes right out, assuming you have the retainer nut on the front loose already.
Posted: Mon Mar 26, 2007 10:37 am
by cowboy
Patrick said it all , after you push the little buttom down & putt out the knob & shaft , you loosen the front screw & it will drop right out
