What's the last year for LH lug nuts
tom-adc
City: LaA
Post by tom-adc »
What was the last year for LH lug nuts?
hotrodjohn68
lh studs
Post by hotrodjohn68 »
on all of my 1/2t trucks i used jeep studs all the way around , or just use all the stock right hand studs for LH.
i hope this helps
john :Thumbsup
cowboy
Post by cowboy »
Tom I think 69 was the last year for the left handed lug nut's , might have been earley 70 I have had 70& 71's with right hand all the way around from the factory
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
The last year was 1970. In 1971, everything Mopar had RH thread all the way around. My '70 Challenger and '70 Darts were LH/RH, and all of my '71 trucks and my old '71 Dart were RH.
tom-adc
City: LaA
Post by tom-adc »
Thanks Pat & John that is what I was looking for my 69 Dart GT had LH but when I converted to disc barkes I did everything RH.
Truck has after market wheels but before I cranked on them I wanted to be sure. I didn't see any knotches on the lug nuts so thought I'd got lucky.
Cageman
City: Bismarck
Post by Cageman »
My 71 has left hand stll, but I am down to just the rear now, as I have a newer stub on it in the front, both of my 70's had left too, but not anymore.
LH
Cageman is right 71 is the last year for LH lugs, my 70 had them for years, became too much trouble so switched :study
Hemikuda71
City: Oklahoma City
Post by Hemikuda71 »
'70 was the last year for the left hand lugs. All the '70 'Cuda's I've owned over the years all had left hand thread lugs on them, even the '70 hemicuda I owned. Cage, your truck could be a early '71. That could explain it having lefts on it.
R/T
'61 D-100 Utiline
'62 D-100 SWB
'64 D-200 LWB CSS 1 of 2 known 3/4 ton CSS's
'68 A-100 Pick Up (stolen)
'72 Challenger
'78 "Lil Red Express"
'97 Dakota Club Cab
LH lugs
oneowner71 also had LH lugs on his :study I think the trucks carried them for another year after the cars quit??
Hemikuda71
City: Oklahoma City
Robin, one thing that my friend PL and I've noticed is that when Chrysler wanted to get rid of no longer used parts on the cars they used them on the trucks. HHHMMM.... that would explain the lefts on the '71's. Thanks Robin.
R/T
'61 D-100 Utiline
'62 D-100 SWB
'72 Challenger
'97 Dakota Club Cab
duracell
City: Peoria,Arizona
Post by duracell »
my 70 came with and still has left hand threads
as always and sometimes not,steve
steven
Post by steven »
My '71 challenger has RH/LH lugs. The car is untouched :withstupid
1974 Dodge D600 318 5+2
2003 Ram 2500 Cummins HO
sireland67
Post by sireland67 »
My 71 d-100 truck has RH lugs.
My 71 Challenger had RH lugs.
My 71 Cuda had RH lugs.
My dad had a 70 d-100 that had RH lugs, he bought the truck new.
tom-adc
City: LaA
Post by tom-adc »
My 71 D100 has RH just checked using a torque wrench.
Of course I don't know if the previous owner did that or the Air Force did it?
VintageMopar
City: Mount Shasta
last year for LH threads on wheel mounting studs
Post by VintageMopar »
The last year for LH threads (on L side only) is different (sooner) in cars than trucks. I second the comment of another member that when changes or "improvements" were introduced by Chrysler, cars saw the change before trucks, and at least as regards steering column ignition key, trucks (1972) saw the change before vans. I believe the last year in cars was 1970 (I have a 70 Plymouth Belvedere) w/ LH threads. My 71 D100 and 72 D200 both have LH threads, so you can figure any sweptline era 61-71 Dodge truck w/ RH threads only must have had those studs on the left side replaced at some point. Usually if a shop breaks one they will change all of them on that wheel. Hope this helps
My '71 W200 had LH studs.
dylansd100
Post by dylansd100 »
My 69 had LH, went down to auto zone and paid 10 bucks for 20 RH studs and put those in
69 d100 adventurer 318 four bbl.
727 / 3.55 rear
Massively Over Powered And Respected
Mutilates Other People At Races
VintageMopar
City: Mount Shasta
Last yr for LH threads
I slightly screwed up my previous post to this question, going from memory. My 71 D100 has RH threads all around and paint on them matches the truck, so I would say they are all original. But it is possible Dodge changed threads on the 1/2 tons, which used the same 5-stud wheels as the cars, in a prior year than when they changed threads on 3/4 ton and up. I still think my 72 D200 has LH threads on driver side, but couldn't tell by inspection becase it has acorn (closed end) nuts and I didn't have time to play with them. Will post again when I have checked them, but the original poster ADC-Tom was asking about a 71 D100.
