Bed repair
Quackhunter1975
City: Chandlerville
State: IL
Bed repair
Post by Quackhunter1975 » Sun Feb 04, 2018 5:47 pm
Finally gathered enough parts to start my project. Question is how do you go about replacing outer bed panel if floor is good?
Quackhunter1975
City: Chandlerville
State: IL
Re: Bed repair
Post by Quackhunter1975 » Mon Feb 05, 2018 12:39 pm
Just wanting to know if it is spot welded to inner bed side and if possible to separate the outer from the inner.
Re: Bed repair
Post by Hobcobble » Tue Feb 06, 2018 1:01 pm
What year box? :thinking
Re: Bed repair
Post by PwrWgnDrvr » Tue Feb 06, 2018 1:08 pm
John, its a yr with inner wall panels.....therefore, NOT pre 65.5
Jim100
City: Kalamazoo/MI
Re: Bed repair
Post by Jim100 » Tue Feb 06, 2018 3:20 pm
Removing the inner bed( ribbed) from the outer (swept part) is a spot welded pain. I couldn't do it. Not to say you cant though. Spot weld drills and or grinding. The top is what did me in.
Quackhunter1975
City: Chandlerville
State: IL
Re: Bed repair
Post by Quackhunter1975 » Tue Feb 06, 2018 8:27 pm
Ok. Was afraid of the spot welds being a pain. I have 4 beds to try to make one good one. One is 65.5 two are 68 and last one is late 69-71 it has the dude markings on it. Trying to just use the 65.5 and the 68’s. Thanks for info.
Jim100
City: Kalamazoo/MI
Re: Bed repair
Post by Jim100 » Wed Feb 07, 2018 5:48 am
Depends on if you want perfect show type or frankentruck (mine) or in between. With some carefull cutting in hidden areas with maybe a plasma cutter you should be able to get something .
Good luck.
