What did you use to clean Chrome
Chrome with paint on it?, tried just soapy sponge but the paint is their. Alcohol?
Panelbeater02
Re: What did you use to clean Chrome
Post by Panelbeater02 »
You can use paint stripper, or, very fine steel wool. Lacquer thinner will work too. Depends if you are removing overspray, or something like a chrome bumper that has been painted. If you use fine steel wool it won't scratch the chrome. I have used combos of all three.
Panelbeater
Yes its paint,
and I thought paint thinner would work but couldn't remember if it would hurt the chrome, I have steel wool also but was afraid of scratching the chrome, thanks I had a Blonde moment :Thumbsup
I use 0000 steel wool.
I think I have a couple of those left, if not I'll need some to stock my new Garage :lol: almost manly shopping time, after we get moved and set up, I'll have to enventory my depleted stock and go man shopping! AAARRR, AAARRR, :goodpost
wooferdog
City: WA State
Post by wooferdog »
I know somebody who polishes the old chrome on their Dart with aluminum foil. It works. Shiny side out. Less abrasive than even 0000
It parked when I ran it
I never gamble when I cheat at cards
bluefury
City: Pinson Alabama
Post by bluefury »
Spray on oven cleaner will not harm the chrome. Anything abrasive, even 0000 steel wool, will scratch the surface, although I have used 000steel wool saturated with WD-40.
nfury8
City: KC, MO
Post by nfury8 »
Lacquer Thinner. It will munch on all but the hardest of paints,
no matter what the age. I was using it to remove some of the
ancient paint the Forestry Service had on my Crew!
And it will not touch Chrome. So far the only Paint I have found it
will not quickly soften it POR-15, but it will over a long exposure.
There is always Brake Fluid! It will even take off POR-15, I know.
It is glycol based, and will not hurt chrome either.
You should also be able to use a grey (Ultra Fine) Scotch Brite pad.
They are finer than steel wool. Might actually make a weathered
chrome bumper look better, but might slightly dull a fresh, mirror
finish bumper.
Also try a product called Never Dull, it is a solvent/polish that
comes pre applied to natural cotton hunks. Should be able to
find it at most parts stores, maybe even Wal-Mart. This stuff
really works! My uncle turned me on to it one day, when he used it
to clean melted sneaker rubber off the chrome pipes on his Harley.
It might not be strong enough if the paint is fully cured, but would
be great to follow up the Lacquer Thinner with.
wooferdog
City: WA State
Post by wooferdog »
Never dull is a good product. I used it to polish an aluminum valve cover on an old Alfa Romeo I owned. One thing, be prepared to use some serious elbow grease with this stuff. Result will come out though. It's also re-usable up to a point. Have you tried Brasso on the effected area. I've had some luck with Ronsinal (lighter fluid) as well.
Nobody has mentioned good old Naval Jelly. Used Sparingly
cowboy
Post by cowboy »
you can also check out this guy , I found it at a motorcycle swap meet & have been useing it sence www.gordsaluminumpolish.com he has videos to show you how to use it I use it on my Harley's chrome & my trucks chrome
Dave :usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
well I went to my old reliable-gasoline :lol: couple of minutes of soaking and the paint came off, I went and bought buff pads and compound, now will repaint the area behind 100, the color, well wait until I post the picture :lol: :lol:
