My '68 D100
- City: Jacksonville
My '68 D100
I bought a D100 last year and debated trying to get it running. The motor was locked up. I ended up coming across a buick roadmaster for cheap and decided on a frame swap to the truck.
I still need to do bumpers and wiring for the lights/blinkers/wipers, but it's coming along. I can drive it around the yard now anyway. I just ordered some drop spindles for the front, as it needs to come down.
anyway....
anyway....
Re: My '68 D100
According to Wikipedia, the wheelbase of the Roadmaster is 115.9". Your truck appears to be a long bed with a 128" wheelbase. How did you make them fit together?
Re: My '68 D100
Roadmasters have been around since 1936. Maybe its of a different generation?soopernaut wrote:According to Wikipedia, the wheelbase of the Roadmaster is 115.9". Your truck appears to be a long bed with a 128" wheelbase. How did you make them fit together?
Re: My '68 D100
i stretched the roadmaster frame...
Re: My '68 D100
it's a '94Hobcobble wrote:Roadmasters have been around since 1936. Maybe its of a different generation?soopernaut wrote:According to Wikipedia, the wheelbase of the Roadmaster is 115.9". Your truck appears to be a long bed with a 128" wheelbase. How did you make them fit together?
Re: My '68 D100
The wheels were my clue that it wasn't an old one.Hobcobble wrote:Roadmasters have been around since 1936. Maybe its of a different generation?soopernaut wrote:According to Wikipedia, the wheelbase of the Roadmaster is 115.9". Your truck appears to be a long bed with a 128" wheelbase. How did you make them fit together?
Re: My '68 D100
looks good, id love to see some pictures of how you did the swap if you have any.
1966 Dodge D100 Custom SC SWB
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
Re: My '68 D100
Ahh.... I'm with you now.soopernaut wrote:The wheels were my clue that it wasn't an old one.
Re: My '68 D100
Jake66 wrote:looks good, id love to see some pictures of how you did the swap if you have any.
i didn't take too many pics, but this is what i've got....
the roadmaster when i brought it home...
cab set on the roadmaster frame...
working on some rust repair...
i wanted to keep the sweptline gauges, but they were all wrong for the roadmaster drivetrain.... so, i cut down the roadmaster gauge cluster so it would fit in the sweptline dash.
before stretching the frame...
mounting the bed....
Re: My '68 D100
Looks good, what motor and transmission did the roadmaster have in it? Im guessing the 5.7 with a 700r4. Did you use the drive train from the ringmaster?
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
Re: My '68 D100
yea.... it's the LT1/4L60e with a 2.93 and limited slip rear end according to the internet.
with that rear gear, it should cruise on the highway pretty well.
Re: My '68 D100
Did you have to cut the bed floor to get it to sit on the new frame? It looks like you would have to unless there are really tall mounts that hold the bed just above the frame kick up. I think I see daylight in the shadows of the 1st picture though.
Re: My '68 D100
yes, i removed most the bed floor. my goal is to be pretty low.soopernaut wrote:Did you have to cut the bed floor to get it to sit on the new frame? It looks like you would have to unless there are really tall mounts that hold the bed just above the frame kick up. I think I see daylight in the shadows of the 1st picture though.
i figured since i was going to make a new higher floor, there wasn't much of a reason to keep the old floor... and it was easier to make mounts with the floor out, instead of pulling the bed off again.
if it was about half an inch higher it would only need to be cut out for the frame at the wheel wells.
Re: My '68 D100
the roadmaster wheels actually look pretty good on there. do you plan to keep them?
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
Re: My '68 D100
nope... i don't know what i'll run for sure, but it'll be a 20ish" wheel.
Re: My '68 D100
been working on wiring today....
got my wipers working and it looks like everything works fine. (linkage, etc)
what do i do for blades? my arm ends are mangled and missing pieces, so i can't just do inserts.
Re: My '68 D100
hmmmmm....... maybe cruise around on ebay and see if anybody has some? ill do some looking around and see if i can find any reman stuff.
http://phoenix.craigslist.org/nph/pts/4542924736.html found some that might work.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
Re: My '68 D100
been driving it a little.... even got caught in the rain a couple times. thanks rain-x!
at t-ball practice...
and next to my buddies chevy.... i need to get my bumpers on really bad. lol.
Re: My '68 D100
Glad you got it on the road! Good feeling once your able to drive something you've put so much work in to and see it pay off.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
Re: My '68 D100
Jake66 wrote:Glad you got it on the road! Good feeling once your able to drive something you've put so much work in to and see it pay off.
no doubt. its very motivating to finish things once you can finally drive it.
