just goofing
- oklamopar
- City: Midwest City OK
just goofing
Well for a bit of back story. I work at a a salvage yard that does alot of Chrysler products.
We had an 06 300 come in, it was hit hard in the left front, but 3 of the aftermarket wheels were still ok.
I had, at another time taken one of my factory swepty 15" wheels to work, and I put it on the rear of a magnum, just for curiosity's sake. and it fit.
so i brought home 2 of the good wheels.
No Its way to much chrome. But they fit.
Just for giggles...and its on Justins 70 not my 69
Re: just goofing
Not exactly my style, but it kinda works!
- oklamopar
Re: just goofing
Yeah. That's what we think too. To much chrome. Just did it to verify bolt pattern and offset
Re: just goofing
If you were to run 115mm bolt pattern wheels on a Sweptline you would probably want to get hubcentric rings or this could happen. It was on a GM car so they were using 4.5 inch bolt pattern wheels on a 115mm bolt circle.
ASA's ended up being the wrong bolt pattern. When I bought 'em Sept 08 they were listed as 5x115. I never gave it a second thought when I installed 'em. Then I started to break wheel studs. One here and there and I thought it was an overzealous tech from the previous owner stretching 'em and I'm breaking them.
Then the replacement studs started to break, then I inspected the wheels to find out they were 5x114.3.
It wasn't pretty
four broke
- oklamopar
Re: just goofing
with the aftermarket wheels we tried, the center hole was a snug fit both front and rear. no place for the hubcentric. but i too have ran into the same issue
Re: just goofing
Maybe a little black powdercoating and those wheels would look absolutely beautiful.
- 66patrick
- City: Central
Re: just goofing
You see a lot of the later wheels on earlier vehicles, and nearly all end up with the same results. 115mm is NOT the same as 4-1/2"! It's 114.3mm. It causes a great deal of stress on the lug bolts, with the results you see before you. People either don't realize this problem, or figure "ahh, it isn't going to happen to me!"...and tire/wheel stores surely do not help this, either.
Re: just goofing
66patrick wrote:You see a lot of the later wheels on earlier vehicles, and nearly all end up with the same results. 115mm is NOT the same as 4-1/2"! It's 114.3mm. It causes a great deal of stress on the lug bolts, with the results you see before you. People either don't realize this problem, or figure "ahh, it isn't going to happen to me!"...and tire/wheel stores surely do not help this, either.
Is there a way to compensate for the difference? I would like to put those style wheels on my fifth avenue.
Re: just goofing
In short..... no.NationPerformance wrote: Is there a way to compensate for the difference? I would like to put those style wheels on my fifth avenue.
