69 D100 > W100 more pics
- moparbay
- City: Rapid City
- State: SD
More pics
moparbay
Ole "Blue" 68 D100 Adventurer
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
- Boons
- City: Innisfail
Re: 69 D100 > W100 more pics
Were did you score those shifter boots?
1989 Ramcharger LE 318/727 2wd (For Sale)
"FUBAR"1971 Fargo D-100 LA 318/727 Auto
"SNAFU"1968 Fargo W-200 POWERWAGON 383/Np 435 4 speed/Np 202 T-case.Dana 60 rear Dana 44 front
- PeacefulChaos
- City: Rockaway Beach
- State: MO
Uhm... <------ Feels like a retard...
But what is the second shifter? I see two... Or is that a shifter at all?
I'm such a noob.
I'm such a noob.
1964 D200 225 /6 manual 4 speed granny gear My very first car.
1979 Ford F-250 Ranger 460 V8 automatic Daily Driver (KC)
2002 Ford E-150 Triton V8 automatic Family Car/Daily Driver (KC)
2006 Chevy HHR V6 automatic Family Car/Daily Driver (RB)
1991 Lincoln Towncar V6 automaticFamily Car/Daily Driver (RB)
1991 Ford F-250 automaticHaven't been under the hood, and needs a lot of work! Work truck (RB)
~Life is a journey, and there is never a road too rough, a place too far, or a sight unseen. Just take the time to enjoy it as it comes.~
- surfnuke9
- City: Churchton
Long one is the trans shifter, shorter one is the shifter for the transfer case.
Tim
A little lesson for ya.PeacefulChaos wrote:Uhm... <------ Feels like a retard...
I'm such a noob.
When you see a W in the type of truck description ,that designates 4 wheel drive . D then is a two wheel drive.
D200 is 2 wheel drive 3/4 ton.D100 is 2 wheel drive 1/2 ton.
W100, W 200 ,W 300 and so on, are all 4 wheel drive or 4x4.
Welcome to the Swepty College.
"Hewy"
1964 D100 318 poly sweptline
1964 D100 225 /6 short utiline
- moparbay
- City: Rapid City
- State: SD
they are just some universal boots I pickedup at O'reilly's, but you could probably get them at any parts store.Boons wrote:Were did you score those shifter boots?
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
Did you do the conversion ?
Was there a lot of reconfiguring to do ? I'm thinking there must have been.
"Hewy"
- Boons
- City: Innisfail
mine are toast and all the ones ive ever found look like crap or can only mount on a flat surface.moparbay wrote:they are just some universal boots I pickedup at O'reilly's, but you could probably get them at any parts store.Boons wrote:Were did you score those shifter boots?
- moparbay
- City: Rapid City
- State: SD
Yes, I did all the work. Pretty much everything bolted up except the transmission cross member and the rear drive shaft which I had to have made at a local shop. I also had to change the rear axle parking brake cables cause they were not the right length and the master cylinder is for a 74 dodge 1/2 ton truck because of the front disc brakes.The front drive shaft works but the slip yoke is worn and will need replaced. The hardest part was having to do the work twice because the all of the first donor truck parts were wore out. In fact, the only thing that survive from the the first truck is the 4 spd bell housing. I kept '85 front springs but I had to use a set of 3/4 ton rear springs i had laying around from different project as the center pin is offset about 1.5 inches (I think) in the post 71 trucks and causes the rear axle to sit too far forward in the rear wheel wells.Hewy wrote:Did you do the conversion ?
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
- moparbay
- City: Rapid City
- State: SD
The ones I got did not mount that good but I made them work the best I could. I think if a guy were to make their own retaining ring to fit the conour of the dog house the rubber boots would conform pretty good. I would love to find some period correct boots (Hint Hint you guys...).Boons wrote:mine are toast and all the ones ive ever found look like crap or can only mount on a flat surface.moparbay wrote:they are just some universal boots I pickedup at O'reilly's, but you could probably get them at any parts store.Boons wrote:Were did you score those shifter boots?
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
- PeacefulChaos
- State: MO
So that means... ALL Ws are 4 wheel drive? And how does the double shifter work? I mean... when you're driving in snow for example, do you just shift one then the other?...Hewy wrote:A little lesson for ya.PeacefulChaos wrote:Uhm... <------ Feels like a retard...
I'm such a noob.
Man, and I thought driving my truck was complicated... D: Looks like I need to read up on some things...
- thembsnyder
- City: Decherd
P/C,
The tall shifter is your typical manual transmission shifter to shift between 1,2,3,4,R. The second smaller shifter is to put the truck into the 4 wheel drive ranges, 4L (4 Wheel Drive Low), 4H (4 Wheel Drive High), 2H (2 Wheel Drive High), and Neutral. Typically if you are going to go 4 wheeling you can cruise around in 4H, if you get into something sticky or are going to climb a hill you will shift down to 4L, this drops the gearing down in the transfer case. Cruising the highway will be 2H.
This is very generic and I am not positive if all the dodges are the same for the lettering.
Hope this helps
Hope this helps
A blind squirrel finds a nut every now and then
- PeacefulChaos
- State: MO
Quite a bit... Thanks. My mom tried to explain it to me, but she... Was wrong? And dad was frustrated when he got home, then left back for work not an hour later.thembsnyder wrote:P/C,
Hope this helps
Just learned how to drive a stick... Still not all that great at it. But to add 4WD would be... I couldn't imagine not being frustrated trying to drive it.
To add more transfer case confusion, the 61-68 4 wheel drive trucks had a 2 lever transfercase. They didn't come with automatics either so you would have 3 shifter levers.
- PeacefulChaos
- State: MO
Oh dear... O.O I couldn't function in a truck like that. XD Too many things to do... I'm not that great with multitasking... Especially while driving.soopernaut wrote:To add more transfer case confusion, the 61-68 4 wheel drive trucks had a 2 lever transfercase. They didn't come with automatics either so you would have 3 shifter levers.
- jwing68
- City: Lethbridge,Alberta
You would be suprised how easy it is to operate the three stick setup don't be intimidated by the three sticks, the most common problem is people trying to shift from 4 high to 4 low or visa versa on the fly this is diificult to accomplish and is very hard on the drive line components. The Dodge people were very smart to build the W's this way since it is simple, functional and way cool which is why so many aftermarket vendors are now supplying two stick T-case shifters for Jeeps and so on for that cool factor.
66 Fargo W100 Sweptline SWB Poly 318
67 Fargo W100 Sweptline SWB Poly 318
68 Fargo W300 dually LA 318
66 Dodge W200 Poly
65 Dodge W300 dually Poly 318
68 Pontiac Firebird 350
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
- PeacefulChaos
- State: MO
I had enough problems driving my truck... After all, I practically learned to drive on an automatic... In an 02' E-150... >.>jwing68 wrote:You would be suprised how easy it is to operate the three stick setup don't be intimidated by the three sticks, the most common problem is people trying to shift from 4 high to 4 low or visa versa on the fly this is diificult to accomplish and is very hard on the drive line components. The Dodge people were very smart to build the W's this way since it is simple, functional and way cool which is why so many aftermarket vendors are now supplying two stick T-case shifters for Jeeps and so on for that cool factor.
One stick distracts me enough... Two... Would be horrible... three... Might as well take my license now... Lol
- magnumcid
- City: Sherbrooke
I have the 3 stick setup. It isn't complicated at all. It drives just like a 2WD unless you want to use 4WD, in which case you stop the truck, engage the front axle, and select HIGH range or LOW range. Then it drives the same as a 2WD again (Except you don't get stuck ) You don't use the other shorter shifters unless you're stopped. Since my front diff is broken, I haven't tried my 4WD... I'm curious just how slowly i can crawl along in 4LOW with my 4.10s in 1st gear... it's like freakin' 6:1
1967 Fargo Power Wagon 200; Poly 318/NP435/201/4.10s PROJECT
1996 Chebby S10 ZR2; 4.3 Vortec/5 Spd./Manual 4x4 OFF-ROAD BEATER
2003 Chebby Cavalier; 2.2 Ecotec/Auto DAILY BEATER
- City: Glendale,
- State: AZ
That speed is about 10 mph top end. Jimmagnumcid wrote:I have the 3 stick setup. It isn't complicated at all. It drives just like a 2WD unless you want to use 4WD, in which case you stop the truck, engage the front axle, and select HIGH range or LOW range. Then it drives the same as a 2WD again (Except you don't get stuck ) You don't use the other shorter shifters unless you're stopped. Since my front diff is broken, I haven't tried my 4WD... I'm curious just how slowly i can crawl along in 4LOW with my 4.10s in 1st gear... it's like freakin' 6:1
03 Hemi Ram 2500
My '68 W200 has 4.88/489 gears. In 4LO, 1st gear, Imagnumcid wrote:I have the 3 stick setup. It isn't complicated at all. It drives just like a 2WD unless you want to use 4WD, in which case you stop the truck, engage the front axle, and select HIGH range or LOW range. Then it drives the same as a 2WD again (Except you don't get stuck ) You don't use the other shorter shifters unless you're stopped. Since my front diff is broken, I haven't tried my 4WD... I'm curious just how slowly i can crawl along in 4LOW with my 4.10s in 1st gear... it's like freakin' 6:1
can walk alongside the truck.
