69 D100 > W100
- moparbay
- City: Rapid City
- State: SD
69 D100 > W100
Here are some pictures of my 69 D100 turned 4 wheel drive. Engine is a 65 413 out of a new yorker, front end/rear end, 4spd, np 208d transfer case are all out of a 1985 w150. This was the second drive train swap as the first was from a 78 w200 and after the swap the front/rear end, transmission (4spd), transfer case (NP203) were all junk and i couldn't hardly drive the truck. The seats and center console are out of 91 d250. enjoy some pics.
moparbay
Ole "Blue" 68 D100 Adventurer
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
Re: 69 D100 > W100
That thing is cool! I love 413's!!
- magnumcid
- City: Sherbrooke
Re: 69 D100 > W100
Looking good! Are those 33s or 35s?
1967 Fargo Power Wagon 200; Poly 318/NP435/201/4.10s PROJECT
1996 Chebby S10 ZR2; 4.3 Vortec/5 Spd./Manual 4x4 OFF-ROAD BEATER
2003 Chebby Cavalier; 2.2 Ecotec/Auto DAILY BEATER
- moparbay
- City: Rapid City
- State: SD
Re: 69 D100 > W100
33s on 15x8 wheels, the only rubbing I have is on the drag link. The only lift is what the '85 front springs provided if any. I am looking to raise it up another 3-4 inches but I do not want to use rear blocks and I cannot find any rear springs that have the center pin in the right location and I don't want to spend the money on custom springs.magnumcid wrote:Looking good! Are those 33s or 35s?
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
Re: 69 D100 > W100
In case you didn't know, '68 and earlier W100s & W200smoparbay wrote:33s on 15x8 wheels, the only rubbing I have is on the drag link. The only lift is what the '85 front springs provided if any. I am looking to raise it up another 3-4 inches but I do not want to use rear blocks and I cannot find any rear springs that have the center pin in the right location and I don't want to spend the money on custom springs.magnumcid wrote:Looking good! Are those 33s or 35s?
used factory rear lift blocks.
- tastypinecone
- City: Tucson
- State: AZ
Re: 69 D100 > W100
is that a van or Ramcharger rear bumper?
Remember, no matter where you go, there you are.
1965 D100
1965 D100
Re: 69 D100 > W100
Factory Sweptline rear bumper-69-71...tastypinecone wrote:is that a van or Ramcharger rear bumper?
- magnumcid
- City: Sherbrooke
Re: 69 D100 > W100
hmm... I sort of had my heart set on 33s and was pretty sure they wouldn't rub... maybe it has something to do with the offset of the wheels?moparbay wrote: 33s on 15x8 wheels, the only rubbing I have is on the drag link. The only lift is what the '85 front springs provided if any. I am looking to raise it up another 3-4 inches but I do not want to use rear blocks and I cannot find any rear springs that have the center pin in the right location and I don't want to spend the money on custom springs.
- moparbay
- City: Rapid City
- State: SD
Re: 69 D100 > W100
Yeah i know but blocks stink all you gain is height not any suspension performance. I might just have to relocate the spring perches so I can use 72-93 rear springs. Something to think aboutHobcobble wrote:In case you didn't know, '68 and earlier W100s & W200smoparbay wrote:33s on 15x8 wheels, the only rubbing I have is on the drag link. The only lift is what the '85 front springs provided if any. I am looking to raise it up another 3-4 inches but I do not want to use rear blocks and I cannot find any rear springs that have the center pin in the right location and I don't want to spend the money on custom springs.magnumcid wrote:Looking good! Are those 33s or 35s?
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
- moparbay
- City: Rapid City
- State: SD
Re: 69 D100 > W100
Yep, I got it off a '70 d100 in a local savage yard.soopernaut wrote:Factory Sweptline rear bumper-69-71...tastypinecone wrote:is that a van or Ramcharger rear bumper?
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
Re: 69 D100 > W100
I've Dreamt of converting my 69 D200 Camper Special to 4 Wheel Drive for years! is it difficult?
Re: 69 D100 > W100
rough country makes a kit says 70 and newer, I have it on my 69 and it seems to fit ok. you will need to extened your driveshaft though.moparbay wrote:33s on 15x8 wheels, the only rubbing I have is on the drag link. The only lift is what the '85 front springs provided if any. I am looking to raise it up another 3-4 inches but I do not want to use rear blocks and I cannot find any rear springs that have the center pin in the right location and I don't want to spend the money on custom springs.magnumcid wrote:Looking good! Are those 33s or 35s?
"American Iron"
- moparbay
- City: Rapid City
- State: SD
Re: 69 D100 > W100
I didnt think it was tough but it was really labor intensive and cost a lot more than i figured. its all the little stuff that really brings the total cost up like drive shafts and brake lines and other stuff i didnt think about.TheVictor wrote:I've Dreamt of converting my 69 D200 Camper Special to 4 Wheel Drive for years! is it difficult?
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
Re: 69 D100 > W100
Thanks for the heads up. I'll make sure to save up a bit of cash before I dive into the conversion. I'm glad to hear that its not too terribly complicated.
Thanks Much
Thanks Much
