- 66patrick
- City: Central
No, it's with the flipped axle.
Is there a thread somewhere that explains how to do the axle flip? thx66patrick wrote:No, it's with the flipped axle.
- 66patrick
- City: Central
No, how to UNDO the flip.
- facechicken
- City: Baileyville
- State: KS
axle flip is a bad idea.....dropped axle is the way to go or take out some springs(which can cause other issues)
It is wiser to "drop", than to "flip"....EdAbbey wrote:Is there a thread somewhere that explains how to do the axle flip? thx66patrick wrote:No, it's with the flipped axle.
Do a search as there are plenty of threads on this topic.
- City: lake anna
- State: VA
my 70 d100 survivor..
That is a RAD truck man. I dig the stance.
- 66patrick
- City: Central
Very nice truck.
- vroc4507
- City: Sanborn
- State: IA
I have read a few posts on the axle flip and it definitely seems to be a lot less costly than a dropped axle. Can you explain further on why the flip is a bad idea?facechicken wrote:axle flip is a bad idea.....dropped axle is the way to go or take out some springs(which can cause other issues)
Thanks, BK
- City: Wisconsin Rapids
- State: WI
Very nice!!71superbee wrote:my 70 d100 survivor..
Joel
- Oldguy
- City: Reno
- State: NV
BK, flipped axles in the front can cause bump steer. That is really bad since you can not steer the vehicle when you hit a bump just right. Very scary if you've ever had it happen to you! Hope this helps. Mike
- vroc4507
- City: Sanborn
- State: IA
Thanks man, appreciate the heads up! I figured there was a good reason just had to know. Also my apologies for highjacking the thread, I just had to ask.Oldguy wrote:BK, flipped axles in the front can cause bump steer. That is really bad since you can not steer the vehicle when you hit a bump just right. Very scary if you've ever had it happen to you! Hope this helps. Mike
- Oldguy
- City: Reno
- State: NV
Not a problem. You won't know if you don't ask. Mike
- behindthebadge
- City: Ozark
- State: AR
- behindthebadge
- City: Ozark
- State: AR
- jimmy
- City: Spokane
Very Nice!
I can almost see Don Knotts driving it.
- State: WI
That is nice!!
Joel
Joel
- behindthebadge
- City: Ozark
- State: AR
jimmy wrote:Very Nice!
Nip it... Nip it in the bud!
- City: Glendale,
- State: AZ
70 Camper Special with a 383, automatic, PS, PB, air conditioning with a 3.54 sure grip. I moved the fuel tank out of the cab and installed a 33 gal. bronco tank between tho rails, i also went with Scarebird front disc brakes. Jim
- rickharrold
- City: blackwell
Jim, that is nice, I may have it's brother in the color of blue.
