another great find
- sweptlinemike
- City: Arlington
another great find
A friend of mine found this shorty at the junk yard, I went to check it out and found that it has a big block and the body doesn't look to bad (not rusted out) best I can tell is that its a 68?, I couldn't get to the vin plate and the tail light lens said 65 which I knew was wrong. If I can get together the 400 bucks to get it, what I want to do is switch out the cab and hood from my 69 lwb. Is there any differences in the body? I haven't found any information stating so except that there may be a difference in the suspension? My 69 is a factory air truck with power brakes so switching out the cabs makes sense to keep those features plus Ive grown fond of my 69.
- PowerMan
- City: Auburn
Re: another great find
$400 for a big block short bed.... Nice find! The body says its a '68 but you'd have to check the vin.
I believe the size of the dashes from '61-'68 are different from those from '69 to '71. I am not totally sure.
Hopefully someone else can answer the question because I'd like to know for sure.
I am not sure about the cab interchangability.
Your 69 cab will bolt to the 68 frame the body lines are the same , to use your 69 hood you need to change the hood latch on the rad support as the 68 is different
Dave
Dave
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
67 w100 318 3spd
LAND OF THE FREE
- hemihydro135
- City: tucsonaz
mike, buy it and build it! that is a badass truck high options 68 short box with a big block, you can't get any better then this! even if its not all origional that is a very cool truck! good luck
1968 SWB
1964 Crew Cab Power Wagon
1972 Plymouth Satellite
- Outlaw
- City: San Antone
$400!! you can't beat that for the truck w/motor!! Great find! if only i could be so lucky!
1967 D100 - Learning as I go...
- ALindustrial
- City: Abilene, KS 67410
cool truck, and an even better find. ugly steering wheel tho :D ;)
Mike, if you can swing it, I'm with everyone else.. bring it home!
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
- mopardwh
- City: Longview
For sure, snag that one. As far as I know the dash, hood and emblems are the only differences.
- City: CA
if you pick this one up, would gladly take the front right fender off your hands.
- mowingman
- City: Denton, Tx.
That is a 68 hood and 68 Dash. Dash and hood were way different in 69.
Jeff
Jeff
1979 Plymouth Trailduster, 360/auto.
1989 W150 Power Ram shortbed pickup, 318/auto.
1970 W200 Power Wagon long/wide bed, 383/4spd.
- sweptlinemike
- City: Arlington
I did finally buy it, I got it towed to my house for 350 bucks. I decided to work with it and trade off the 69...........
