71 W200 will not crank - "brake" light on key turn
- idaho68d200
Howdy,
Recently picked up my 71 W200 w/383 & NP435. It's been working quite nicely but I parked it one evening at home and went to start it later when I got the "brake" light to come on when I turn the key. I've had the 68 D200 with the 383 and 727 and have observed idenctical behavior on that truck if the transmission is not in park or neutral (or is close to either), but on this truck, the trans is in neutral and for the heck of it I put the t-case in neutral and had the clutch pedal depressed all the way and had my foot on the brake.
The ONLY thing I can even think of is the fact that I changed the front park/turn lightbulbs from clear to amber to go with the clear lenses on the truck, but it just doesn't make sense... My only guesses would be ignition switch or more likely in my mind, starter relay, or ballast resistor... Never had any of these go bad, so prior experience would be helpful.
-Aled
Vehicle collection-->
~49 Plymouth Special DeLuxe L6
~68 Dodge D200 Camper Special 383/727 *FOR SALE*
~68 Chrysler Newport 2dr ht, 383 2bbl
~69 Dodge D200 Adventurer 383/727
~71 Dodge W200 Power Wagon 383/435
The 71 is is a different beast than the 66 that I have under the hood. But, do you get any clicking when you turn the key. With the truck in Neutral have you tried jumping electricity to the solinoid? If it turns over that way, its probably an issue with the wiring or the solinoid. Y'know that there is enough electricity in the battery to kick it over. Brake lights don't use nearly as much electricity as a starter so its possible you are getting a brake light but not having enough juice to power the starter.
Matta
Matta
66 D-100 long bed swept
Shearingmatt@yahoo.com
For that matter, if you are going to do this. make sure that you have the E brake on and the wheels chocked. It wouldn't be all that hard to make a mistake and have the truck drive off with you hanging out of the hood. :-)
Matt
Matt
- idaho68d200
follow up
There are absolutely NO noises when I turn the key and by "brake" light I mean the one on the dash, not the brake lights in the rear. Everything is in neutral, battery is fully charged and has a good connection.
I'm thinking ballast resistor or starter relay... thoughts appreciated
Thanks
Thanks
-Aled
- nfury8
- City: KC, MO
The dash Brake light coming on is typical, and a good indication that the truck is getting juice as it should.
I would do as the others mentioned and short across the starter relay. When you do this it puts current directly from the battery to the starter, a quick and easy way to eliminate a common problem. The starter has the solenoid built in. By jumping the relay you will be able to hear the starter better with your head under the hood. Listen close for any minute sounds. Sometimes a bad solenoid will make a noticable sound, sometimes it can be barely audible. Do the lights dim at all when you turn the key? This is an indication that the starter is atleast trying to pull some juice.
When a ballast resistor goes out the truck should start as normal, but die as soon as the key is released.
I don't know why, but all my older Mopars love to eat starters. Between the 4 of them, I have to diagnose this about once a year.
A bad ballast resister will not cause this problem. If the ballast is bad the truck will crank as normal but die when the key returns to the run position like someone already mentioned. Also the brake light coming on when starting is correct. This is the lamp test, as you probably will never see that light otherwise.
1969 Adventurer W100
starting problem
in cold weather the starter relay can get sticky ,,..seen this happen before. Try tapping on it with a screwdriver- might do the trick. then switch to the newer electronic type to eliminate the old one with contacts....
- Thomas
- City: Grand Forks
- State: ND
I go through a lot of starters too....nfury8 wrote:The dash Brake light coming on is typical, and a good indication that the truck is getting juice as it should.
1968 D100 318 727 373
Someday I'll have a whole quonset full of Dodge Trucks....
- idaho68d200
works now
Thanks for all the suggestions and advice... I made it back into town and right away opened the hood and tapped on the relay. Cranked right over as normal after that.
It's probably something I should just replace since it's cheap, but my buddy with a Ramcharger says he's kept the same old one in his truck but has to tap on it once in a while to make it work...
Thanks...
Thanks...
-Aled
- City: Lawton
Pull the wires off the relay and clean the terminals. That has fixed more then one
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride"
