My truck came with electronic igniton, a fancy hot coil, etc. The charging system never worked, until my mechanic found and replaced a bunch of melted wires under the dash. I've also replaced the coil and the ignition box.
Now the charging system works, but the ignition system is iffy and spark comes and goes. Right now it's gone, but it can come and go in a single I'm-gonna-get-it-running-this-time session.
I blame the electronic ignition. Any suggestions before I replace the distributor to put it back to stock?[/i]
spark, then no spark, then spark.... '67 318
- Jeffc
Ground your EI box to the battery, bet is solves the
problem, just run a wire from a mount hole to the
neg side of the battery.
Other things to check, most coils will need a good ground too at the mounting point, as well as that all important engine to
battery ground........
points
Do like Jeffc said and check your grounds, for melted wires=bad ground. I would in no way go to points, that is a major downgrade grounds you should have: 1, firewall to engine 2, engine to frame (front of engine to frame is the easiest) 3, Bed to frame
Ditto..... switched my '61 D200 & '68 W200 to theJones wrote:I agree with both in the above posts. Stay with the EI. I just switched out the points to EI and love it. I grounded both Voltage Regulator and ECU and it runs real smooth. Starts easier too.
Just my
Keith
MoPar Performance EI set up. Ground both as per
above posts. EI is the way to go
