electrical system upgrade
- spikekid999
- City: sticks of WI
ok i switched the ignition from points to electic but i wanna convert the alternator from 1 field wire ta 2 field wires but im not sure how i would wire up a late 70s-80s voltage regulator.SOME! PLZ HELP ME IM CONFUSED!!
- spikekid999
- Seabee
- City: Houston
You're welcome guys. Also check out the thread "Good electrical Mods" http://www.sweptline.org/modules.php?na ... electrical
and the linked Mad Electrical article linked there. I did the amp guage bypass mod (but haven't updated my diagram yet) when I added power door locks and alarm and was VERY impressed with the results.
- spikekid999
- Seabee
- City: Houston
Wiring was no problem. Mechanically though is a different story. See these threads:spikekid999 wrote: was it hard 2 wire up the door locks?i was also thinin bout addin power windows.
http://www.sweptline.org/modules.php?na ... ower+locks
Still - I think it's worth it. Power windows would be a nice touch. The companies I reference in the above threads offer actuator kits for that as well.
Lots of good intell here. http://www.imperialclub.com/Repair/Elec ... arging.htm
- spikekid999
well i got the volatage regulator n all that hooked up now im just thinkin of tryin 2 think of a way 2 put power door locks in out of a 5th avenue
craig
1973 dodge dart (project Money Eater[urlhttp://www.cardomain.com/ride/2934209[/url]
1987 Chrysler Fifth avenue (Training Day Chrysler)[urlhttp://www.cardomain.com/ride/2647481[/url]
- spikekid999
um im not sure ill have to get back to you on that one after i weld up the hole frome the origanal gas pedal and put a lil bit of a newer one in unless someone else can answer that for you. the amp gauge should just work fine still i havent touched that.
craig
- spikekid999
good to hear you got it workin
craig
