Electrical switch for back up lights
norcal68
Post by norcal68 »
I changed out my tranmission from a three speed to for4 speed (435)many years ago. Where is the switch to activate the back up lights when in reverse?Thanks Norcal68
:usa
JimE
City: Glendale,
Post by JimE »
It sits underneath the tranny hump just below the shifter. If you need the part # to order a new one through the dealer, I can get that for you also. Jim
03 Hemi Ram 2500
norcal68
Post by norcal68 »
Jim a part number would be great! Does it mount to the tranmission or the sheet metal? Thanks for you help. George
JimE
City: Glendale,
Post by JimE »
norcal68 wrote:Jim a part number would be great! Does it mount to the tranmission or the sheet metal? Thanks for you help. George
Here is the #, 4373814. It is a 2 prong switch mounted into the transmission just below the shift tower. Good luck. Jim
03 Hemi Ram 2500
norcal68
Post by norcal68 »
Thanks again for your help! Will this part number work a a '68? I just check with Arizona Parts and there computer shows its for a 1990-'97?George
JimE
City: Glendale,
Post by JimE »
Stay away from AZ Parts, they are pretty much worthless. To the best of my knowledge that part # will work for most np435 (4spd) trannys. Either use Partsvoice.com to search for a dealer with one in stock, or go to your local dealer. Jim
03 Hemi Ram 2500
JimE
City: Glendale,
Post by JimE »
JimE wrote:Stay away from AZ Parts, they are pretty much worthless. To the best of my knowledge that part # will work for most np435 (4spd) trannys. Either use Partsvoice.com to search for a dealer with one in stock, or go to your local dealer. Jim
I just ran the # through parts voice and pulled up no less than 6 dealerships in SoCal & AZ that have that switch in stock. It runs 15-20. Jim
03 Hemi Ram 2500
norcal68
Post by norcal68 »
Jim, Thanks Again!George
