If anyone has a wiring diagram for a 66 D200 camper special I could use a copy of it. My sons truck needs a turn signal switch and since I can't find one I am going to wire in a universal switch. I can get it done without the diagram but it would be easier with one.
Chris
66 wiring diagram needed
Semper Fi! Active duty 1983-1987, VMA(AW)-224
1987 W150, 225, NP435, NP208, my driver
1966 D200 camper special, 318 poly, NP435, sons driver
1987 Ford Thunderbird LX 5.0, wifes driver
- Jeffc
napa has the new switchs, sometimes even in stock.....
I also have the 66 dio in my 'tech stuff' section below.
Thanks for the help everyone.
Chris
I tried my local NAPA, they said they couldn't get one. If you aren't affiliated with a shop they don't really care if they get your business plus I work for Carquest so that probably didn't help either. I'll just wire this one in and be done with it.napa has the new switchs, sometimes even in stock.....
Chris
I decided to give NAPA another try when I got back to work. I asked for a woman I knew wouldn't mislead me, she didn't. NAPA doesn't have it, not through their normal supply anyway. They have the turn signal repair kit but not the switch. They can get a switch from Shee-Mar, part number SM-105, for $165. I can get that one cheaper through my job discount. The universal switch I am going to use is from Shee-Mar also, part number SM-160 and cost me $26. Since I am not concerned about keeping this truck strictly original but I am concerned with it being a safe daily driver for my son, guess which one I am using ;)
Chris
Chris
- Jeffc
Let me check local and I will see if I can get one,
If I can I will pass the number on to you> got one year or so ago, didn't save the box since it was on a buddy's truck, I also have a few good used ones around
including one that looks brand new......A100 vans used the same switch.....
- Jeffc
Napa number 66 Dodge pickup HL6576 $26.89 and they have it in stock.
Dup; that is for the headlight switch, my mistake
I use a ugly stick on my 66 for the signal switch
myself.
I know that the truck switchs after 71 can be used
but mods need to be done to use them.....
myself.
