Headlight/Turn Signal Conflict
Sully
Post by Sully »
Tired of chasing wires!
Turn signal works, but when I turn on the headlights, it doesn't and the headlight burns dimmer than the other.
help!
cowboy
Post by cowboy »
Sully, Double check all your ground's , & your dimmer switch, it's on the floor :lol: , your front blinkers have a ground , & the wires are in the same harness as the head lights , I do not know if they hook together or not there , but they all hook up at the fuse box
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
duracell
City: Peoria,Arizona
Post by duracell »
you may want to pull the steering wheel and look at the wire's for the turn signal switch as well. i had mine out recently and found that the covering for the wire's are cracking and in a couple of spots the wire was exposed i put some electrical tape on those and mine have worked alot better
as always and sometimes not,steve
Jeffc
Post by Jeffc »
GROUNDS, GROUNDS, check your grounds, clean all contact points from the light buckets to the core support, including the grill mount screws. also
run a added ground wire to core support from the battery neg side.
If pulling the headlights on causes the turn signals not to work it is likely a voltage drop issue, the
the flasher not to have enough voltage to make it flash.
If the voltage does not have a good path back to the battery you will have all kinds of strange things going on.
Sully
Thanks Guys...but it still doesn't work!
Post by Sully »
The left turn signal works fine until I turn on the headlights. It lights up and stays on while the headlight remains dimmer.
I have removed all tape from the harness and chased the wires...no shorts that I can tell.
i will try running a ground wire to turn signal and head light wells/pans.
Thanks again
