Headlights cause pulse... and more
- moparpursuit
When I turn on the headlights I get a drop in votage according to the meter. Also when the lights are on I get a dimming and surging of the lights with RPM change. This problem came out of nowhere... where do I start? 71 D200 318
- moparpursuit
- moparpursuit
- POWWAG
- City: Maple Valley
I just went through this. Read this tread!
http://www.sweptline.org/modules.php?na ... pic&t=7364
It turned out to be a weak signal to the VR on my truck. Check all grounds and connections first, then for dead shorts.
Have fun, I did.....Don
- moparpursuit
mparpursut , speedo should be a completey different problum , You will get some dimming from your trucks lights thats just the old style system , But if your getting a BIG DIMMING , start by double checking all grounds & hot wires for beeing loose or dirty , or look for little bumps in the wires as this will be a burnt wire / got to hot for some reason , & did'en burn through
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
67 w100 318 3spd
LAND OF THE FREE
