Hey guys, I need a wiring diagram for my truck. I need to go over everything and make sure that whats there is right, mostly from just the battery to the dash, all the under the hood stuff is my main concern. I have one for a 67 but I don't know how accurate it will be for my truck.
Also if you have a diagram for having a MSD 6AL ignition with it.
Wiring diagram for a 64 D100 needed.
- wideblock
- City: las cruces nm
- State: NM
located in houston huh??? that means you should join us for the texas ralley in league city on june 9th. gonna be about 10-14 of us there if everyone shows up, all from this site. as far as your wireing goes, i dont have a copy of a 64, but i do have early 65. ill scan it here in a sec and email it over. they should be the same. if you need the details on the ralley, theres a post in general topics that has them all.
I will be on vacation then or I would go.wideblock wrote:located in houston huh??? that means you should join us for the texas ralley in league city on june 9th. gonna be about 10-14 of us there if everyone shows up, all from this site. as far as your wireing goes, i dont have a copy of a 64, but i do have early 65. ill scan it here in a sec and email it over. they should be the same. if you need the details on the ralley, theres a post in general topics that has them all.
Yeah I think the 65 one might work.
Thanks.
- wideblock
- State: NM
its scanned and on its way. i did it in the highest resolution so you could blow it up as much as yuou needed to. 1.4megs, on my dial up, says 4 minutes remianing. let me know if you need anything else, i have a factory service manual here for the 4 headlight trucks
- City: Glendale,
- State: AZ
Trey, you have been around long enough to know that is all archived here:wideblock wrote:its scanned and on its way. i did it in the highest resolution so you could blow it up as much as yuou needed to. 1.4megs, on my dial up, says 4 minutes remianing. let me know if you need anything else, i have a factory service manual here for the 4 headlight trucks
http://www.sweptline.com/tech/electric.html#wire
03 Hemi Ram 2500
