Tune Up Parts
HuffPuff
Tune Up Parts
Post by HuffPuff »
Im looking to tune-up my 225 3.7l,.. plugs,wires,points &condenser cap and rotor.The last time I did a tune-up
I cant remember what what kind of parts I used(brands)
What I want to know is what brand(accel,msd,mopar,??...) do you guys Recommend for this motor.Im looking for some performance but $$$ is also a factor.
What do you guys run???
Thank you for any replys.
JimE
City: Glendale,
Post by JimE »
Whatever comes off the parts stores shelf for the most part. Plugs, nothing but Champion for me, I don't do cheap points will spend the extra 4-5 bucks, rotor, condenser, cap is what ever they have. Plug wires only the LLTs, (until the co. goes out of business :moom }. Jim
03 Hemi Ram 2500
cowboy
Post by cowboy »
I'am with jim on the champ plugs & over the counter parts & A good set of 8mm wires
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
Russ
Post by Russ »
Before I'd spend the money on points and stuff I'd convert it to a later model electronic ignition. You can use junk yard parts as the cheapest way to do it or distributor and box from the parts house as next most economical way, or a Mopar Performance kit as the best but most expensive way. For a driver, I'd go the junk yard route if it were me.
1969 Adventurer W100
wideblock
City: las cruces nm
State: NM
Post by wideblock »
$65 and throw a petronix in the factory dist and be done with points from here on out. my truck chews champion plugs for a snack, nothing but autolite here. the better cap and rotor from accel or someone similar is worth the extra cash. compare the over the counter piece to an accel, and the second you pick the 2 up it will become real apparent wich one will last longer. 8mm quality wires all the way as well. ask cowboy, hes driving my old 66 d100 with a poly that hasnt had a tune up in over 2 years. and its running points still. LOL!!! best i figure, thats about 16k miles on that tune up, am i anywhere close dave????
Tune up
I can't be much help here about saving money, I have over 7,000 miles on my autolite spark plugs, THATS THE ONLY THING FOR ME TO CHANGE, I have MSD 6AL and nothing gets changed execpt plugs and cap and rotor, however as most people will tell ya MSD will burn those plugs until their toast, so until they burn down to the last thread on the plug there is no tune up :Thumbsup
HuffPuff
Post by HuffPuff »
Thank you guys for all your input on the subject :Thumbsup
Im thinking of converting to electric ignition, Where can I buy the pertronix kit. I can't find it listed on any of the autoparts websites (napa,advance,autozone,orilley's)?
Jeffc
Post by Jeffc »
jegs.com or summit.com??
may have to call to order since is not
as common as a v8 application
cudajimmy
City: Oklahoma
Post by cudajimmy »
Use any brand but WELLS on your tune up parts.
69 Barracuda Notchback 440
61 D100 SWB Poly Auto
70-D100
City: St. Clair Shores
State: MI
Post by 70-D100 »
I would purchace a new electronic kit from Summit. If you have trouble with installation, their tech support is awsome. Mancini Racing is good too. Junkyard stuff will work, but you won't have the tech support.
I'm sure you'll be happy with electronic ignition.
Have a great day.
:usa
Russ
Post by Russ »
It's always interesting to me to hear of others experiences and preferences, whether it be spark plugs, oil filters, or anything else auto-related. I used to try to change peoples opinions but now I just say use whatever works for you. I personally only use Champion plugs, and usually run them at least 60K miles with no trouble. Also, for a driver with a /6, you are wasting money if you spend big bucks on a set of 8MM wires. A GOOD set of 7mm wires will give you just as good service and cost less and performance will be no different. I've never used a pertronix setup but you have brought up the first problem with your question. Where do you get it and how readily are replacement parts available if your truck should quit running out on highway 78 between Athens and Loganville? (HuffPuff will know where it's at) If you use a Mopar electronic setup you can always find parts, although you will seldom need them. I don't remember ever hearing anything negative about Pertronix so I'm not saying it's not as good as the Mopar, just offering my opinion. As far as the distributor cap and rotor, most any good brand will last a long time. I think a lot of money is wasted throwing away distributor caps and wires long before their useful life is over.
Well, that's my story, and I'm sticking to it, LOL.
cowboy
Post by cowboy »
Russ, your right with the 7mm wires I thought he had a V8
trey your close might be a little more , the only thing weve done beside keep the oil chang , is we had to replace the clutch slave cyl once & all is still good , still nice & loud & fast running :Thumbsup
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
