'69 383 Electronic ignition conversion???
I have a '69 D-200 Camper Special with a 383 and I am in the process of converting to electronic ignition. I purchased the Mopar kit from Jegs and was wondering what kind of improvements can I expect??. Thanks, Brent
- MarsMonster
- City: Seattle/WA
- shaq787
I'm using the Petronix kit and its working great for me. Its also one less thing to check when the truck doesnt start. It will also drive as soon as it starats up on a cold day, as opposed to needing a good 3 to 4 minutes to warm up when i was using points.
~~Alex
~~Alex
Project truck: 67 D-100
tryin to turn it into a hotrod on a very limited budget.
- Jeffc
Mars,
got it on my photo site below in the tech section,
at least the wiring dio......which is what most folks need.
On the MP units, be sure to check your dist vac advance unit, it is adjustable and often will need to adjusted to give the right advance.
I have also used the Pertronix units, happy with them too.......
