Riddle me this....
cudajimmy
City: Oklahoma
Riddle me this....
Post by cudajimmy »
I drove my 67 D100 to work today, and was sitting behind a pickup at a stop light waiting to turn right, and I notice in the reflection from his tailgate, that BOTH my front signal lights were flashing. When I got to work, I looked in the window at it, and it indeed has BOTH sides flashing when on the right signal, but only the left works from the left signal.
.......anyone have any ideas? :study
69 Barracuda Notchback 440
61 D100 SWB Poly Auto
mechaniclese
Post by mechaniclese »
I had this exact same thing happen to me on my 67! For me it turned out to be a wore out turn signal switch in the column. I don't know exactly went wrong in the switch but once I changed it worked fine.
Riddle me this
Sounds like a bare wire, or like suggested the switch in the column, NAPA has them, Irish70 also had to replace his,I have complete confidence that you will fix the truck Keep up the good work :dance
thorman
City: Nope
Post by thorman »
It's the midget under the dashboard banging on things with a hammer again!
duracell
City: Peoria,Arizona
Post by duracell »
yea, take that little ba$%&#ds hammer
as always and sometimes not,steve
motomatt383
City: Durham, NC
State: NC
Post by motomatt383 »
i chased a simular problem once in an elcamino, turned out one of the bulbs, the filament had come loose inside it & was laying across the brighter side prongs. but it caused the system to back feed & light up the front parking lights when the brakes were applied. just a thought, i remember that well cause i tackled it with the entire tool box instead of the almighty KISS theory(keep it simple stupid).
matt
'70 Roadrunner
'40 Dodge coupe
Riddle me this
actually cudajimmy, a few of the spots that is highly likely to create bare wires is 1. the hole in the radiator support 2. behind the radiator 3. close to the back of the fuse box 4. in the fuse box itself where all the volts pass through and start melting the plastic covering. :banghead
PwrWgnWalt
City: Butte
State: MT
If not yet fixed, look at these...
Post by PwrWgnWalt »
If nothing else has worked, you might give this simple thing a try. My '64 W200 did the same thing when I first got it. Turned out it was in the wiring connections! The older pickups didn't have gang plugins that would only hookup one way. You'll find a green and yellow (if memory serves me) wire - and others - coming from the steering column (from turn switch) and leading to an under-dash bunch of connectors (from emergency flasher & headlamp switch). Make sure these track all the way out to your turn signals, mating to the same color - thru the firewall connections, etc., out to the turn lamps. Also, make sure the emergency flasher isn't corrupting the signal (unplug it from the rest to test) - bad flasher?
Let us know what you found out!
Walt :usa
bean
City: Cuba
Re: Riddle me this
Post by bean »
MountainMoparRobin wrote:Sounds like a bare wire, or like suggested the switch in the column, NAPA has them, Irish70 also had to replace his,I have complete confidence that you will fix the truck Keep up the good work :dance
Wait NAPA has the complete switch? Not to long ago i bought a whole column just for a turnsignal switch! And i still need a new one cuz the one i got was a little touchey. MMR you got part # on these?
1965 Utiline D100 Shorty.../6...3spd...orange...102,000 miles.
1970 Shortbox D100...318...727...almond white..467,000 miles...currently in restoration..
1991 Dodge Ram 50
1968 C@^^@R()
My web page: http://www.myspace.com/chainsawdudewitprobs
oneowner71
City: Fort Worth, TX
Post by oneowner71 »
Bean, I don't think they carry the whole switch... all I have been able to find so far is the cam on the top side that holds the cancel rings (the main part that breaks), but that in itself is probably all you need. They are about $10 on the HELP! line at any of the stores that carry it. I can track down the part number this evening when I get home...
Thanks, Clint
1971 D-100, 318 3-spd
1970 Dude, 383 / A727
1971 Plymouth Satellite,
2002 Dodge Ram 1500 Quadcab
