Last Call
- reallylongnickname
- City: Ottawa, Ontario
Last Call
Before I tow this thing to a garage, I`ll try one last thing. I want to go direct with my own roll of wire. solenoid to relay to ignition switch. Do I connect it to the BAT on the switch or ST
last call
you should have one wire from the starter to the relay, also one wire from the batt to the relay on the same post as the starter.
- Hemikuda71
- City: Oklahoma City
Did you check the little relay thats on the back of the volt/amp gauge? I had a similer problem with my Challenger.
R/T
'61 D-100 Utiline
'63 Plymouth Savoy Wagon (ex fire chiefs car)
'64 D-200 Long Wide Bed CSS
'68 A-100 Pick Up
'70 D-200 Crew Cab (Maybe)
'71 Plymouth Barracuda
'72 Dodge Challenger
'77 Plymouth Tail Duster
'78 Plymouth Super Coupe
'89 Dodge Shadow Turbo
'93 Dodge Shadow America
'94 Plymouth Duster
R/T
'61 D-100 Utiline
'68 A-100 Pick Up
'94 Plymouth Duster
- Jeffc
No relay behind the volt/amp gauge on the trucks, so not that.Hemikuda71 wrote:Did you check the little relay thats on the back of the volt/amp gauge? I had a similer problem with my Challenger.
R/T
Sounds like he cooked the voltage/amp gauge, if
your not passing voltage across to both sides of the
gauge then you cooked it; OR you cooked a fused link
under the hood or dash somewere. What year is it agian?
Power feeds one side to the other on that gauge, if your drawing from the battery it reads -, if feeding from
alt it reads +.
