I am wanting to look into a universal wiring kit for my D100.
First question - Has anyone used a U wiring kit?
Second question - In ordering a kit, what Should I look for? How many circuits? How many fuses? Any other considerations?
Thanks, y'all!
Universal Wiring Harness - 61' D100 Info
1961 Dodge D-100
Alberta, Canada
Alberta, Canada
Re: Universal Wiring Harness - 61' D100 Info
stock is the simplest. no pesky fuse box to deal with. system has breakers instead. superior to fuses. thats why airplanes use them. ;/)
- City: Binghamton
- State: NY
I used a universal mopar harness from Ron Francis.
This went in my 60 d 100. I don’t recall how many circuits it was. I do know it was more than I needed.
If I had to do it again I would use the better kit that has a bulkhead connector at the firewall.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
