Ignition lock assembly
patrino
City: Portland
Post by patrino »
Hello!
1966 D200. There's a LOT of slop in my ignition lock. Starting the truck requires a lot of "jiggling the key", to the point where it can be a minute or two of futzing to get the key turned from "lock" to "run"! The slop is in a few axes, too. I had a new key cut, thinking maybe the key was too worn to work the tumblers, but it didn't help.
Removing the ignition switch, I can see the play is between the ignition switch (the female cast aluminum part with the electrical flag terminals on the back) and the lock assembly (the male part that fits into the ignition switch).
I removed the lock assembly from the ignition switch, and that's clearly where the problem is; it takes me a minute or two just to get the assembly to turn.
Any recommendations for a replacement part here? I could take the assembly to a locksmith, but I'm guessing the thing's all boogered by 50+ years of use. Suggestions appreciated!
Thanks, Patrick
martincom
City: Five Points
Re: Ignition lock assembly
Post by martincom »
The parts store will have replacement lock cylinders. It won't match the door locks, but if you have a competent locksmith, they could make it match.
https://www.oreillyauto.com/shop/b/igni ... 100-series
jeffc57
City: vancouver
Post by jeffc57 »
Napa is were I get replacement, both the switch and the keyed part, as above a locksmith can match make it work (might need your old set)
patrino
City: Portland
Post by patrino »
Thank you both!
I was able to pick up a new part from O'Reilly's, and am good to go!
