69 W200 New Ignition Coil-Runs rough, sputters, gas smell
Re: 69 W200 New Ignition Coil-Runs rough, sputters, gas smell
Okay, good idea. Thanks
- 64D100Poly
- City: Vancouver
I had a similar problem on my 318 Poly, turned out something with my alternator was bad and when I changed It never had the issue again. I would go through a set of points every 100 miles and cook condensers, I would try throwing another condenser and see what it does.
Edit: just saw that you switched it to electronic and it fixed it! don't know how I missed that.. I recommend if you have the original/old alternator to change it, mine was charging but had a burned up diode that kept causing me trouble.
best of luck - LB
best of luck - LB
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
