A couple of months ago, I came up with a nice repair for your stock fuel gauge.
This video shows a preliminary test of the regulator. I'll be creating another video soon showing the difference between your original mechanical regulator and my new electronic unit.
This is not an external regulator that some guys have come up with and it has a fail safe design so that if you lose a input ground, it will not fry your gauges.
https://www.youtube.com/watch?v=Es_10H6yLA4
Fuel gauge voltage regulator repair.
- swptln
- City: East Brookfield
- State: MA
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
Re: Fuel gauge voltage regulator repair.
good work!
- City: WADMALAW ISLAND
- State: SC
I might be interested in the repair work you mentioned, got bad Fuel / Temp gauges in my '68
- swptln
- State: MA
email me, swptln69@hotmail.com
There are some preliminary checks you can do to find out what needs to be done before trying to fix it.
Mark D.
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
- City: Tallahassee
1967 D100
Fuel gauge voltage limiter burned out.
Looking for advice.
Can it be repaired ?
Thanks
Looking for advice.
Thanks
- martincom
- City: Five Points
Here you go: viewtopic.php?f=21&t=43914PIRATEUSAF wrote: ↑Tue Jun 28, 2022 7:58 am1967 D100
Looking for advice.
Thanks
This was installed on a 1971 D100. Your 1967 instrument cluster will be a bit different, so the mounting and wire connections will be somewhat different.
- City: Tallahassee
Sure could use some advice.
Fried three gas gauges.
Following wiring diagram from factory manual.
Can’t sort out why I keep burning good gauges up.
Has to be a grounding issue.
Any chance the gauge could be shorting out once it’s installed back into the metal cluster housing???
Advice welcomed!!
Thanks
Advice welcomed!!
Thanks
