Clutch paddle not returning
Installed new clutch master cylinder today bleed the lines removed air goes in to gears fine but peddle is not returning back sometimes not always thanks for any help
Re: Clutch paddle not returning
You need to write properly, with periods at the ends of sentences, as well as bleed and adjust the system properly. Everything works when done correctly, otherwise, you get paddled.
If you are confident the you have bled all the air out of the system, it could be the that the over center spring needs adjustment. Increase tension on the overcenter spring using a 11/16" open end wench on the adjusting nut until pedal will not return to normal position when actuated. Back off adjusting end nut approximately 1 1/2 to 2 turns or until good pedal returnability is achieved.
There you go..... Western Union style.PwrWgnDrvr wrote: ↑Tue Oct 08, 2019 8:47 pmYou need to write properly, with periods at the ends of sentences, as well as bleed and adjust the system properly. Everything works when done correctly, otherwise, you get paddled.
Oh.... and no paddling here. We don't promote violence [STOP ].
And don't forget to lubricate pedal bushings. Lack of looby can cause the no return pedal.
