65 D100 wiper motor/switch wiring
whitemp
City: Princeton
State: WV
Post by whitemp »
Hello all.My 65 came with a bad wiper motor and the switch had been replaced with a cheap toggle switch.I found a good new motor and switch but not sure of wiring.All online wiring schematics for 65 show motor with A black and a blue wire.Mine has a black and green.Also the switch has 3 terminals .One marked P one B and one R.Can sometime please tell me the proper wiring so I don’t mess up my replacement parts. Thanks so much.Trying to post pic as well!
Willtaft
City: Las Vegas
State: NM
Re: 65 D100 wiper motor/switch wiring
Post by Willtaft »
I've got a question for you where did you find your wiper motor I've been looking for one?
martincom
City: Five Points
Post by martincom »
Post a photo of your switch so the terminal markings can be read.
1*1971 D100 318 A/T
swptln
City: East Brookfield
State: MA
Post by swptln »
On your switch:
P=Park
B=Battery/Accessory Power
R=Run
Your wiper motor should have Black and Blue wire, Black goes to "R" on your switch and Blue goes to "P" on the switch.
You should have a Light Blue 14 AWG going to "B" on the switch.
If it's an aftermarket or rebuilt motor, most likely the Green is the same as Blue.
Hook a ground to your housing of the wiper motor and connect both the black and green wires to a positive feed, the motor should run. Remove the black wire with the green still connected and it should park. If it does, just hook the green wire to "P" on your switch and Black to "R" and you should be good.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
