Help with vacuum heater switch wiring
Not sure where the yellow wire and the red wire plug into the indicated terminals on my new vacuum switch? Any help is much appreciated.
- pwadventurer
Re: Help with vacuum heater switch wiring
One of the two wires goes to 20 amp fuse, the other goes to evap temp control switch. My guess would be that its a switch and doesn't matter.
