As I am working on my late Grandfather's Power Wagon, I am sorting out the various bugs from sitting for 17 years. I did drive it through my neighborhood for the first time a couple of days ago. I noticed the fuel sending unit wasn't working. I began by removing it from the fuel tank. I first took emery cloth and began remove the rust and scale from the outside. I used my Dremel with a round wire wheel to further clean the exterior of the unit. The brass float had a hole in it so I used a plastic one I had from a different project. The I straightened the 3 tabs that enclosed the arm and contacts and pulled that apart. I used 0000 steel wool on the thin wires to gently remove the tarnish. I used the wire wheel on the brass tab on the swing arm and lightly touched and removed the tarnish and corrosion from it. I supported it with my finger from below to keep it from bending out of shape. I checked it with a multimeter and it showed to be working a variable resistance when I moved the arm. I then reassembled the unit and placed it back into the fuel tank and turned the key to the on position and my fuel gauge is now working as it should.
You can click on the link to view my photo bucket to see the before and after pictures. When I figure out how to size my pictures I will start posting the pictures instead of a link.
http://s325.photobucket.com/user/DodgeB ... t=2&page=1
Repairing My Fuel Sending Unit
- City: Charlotte
- State: NC
Re: Repairing My Fuel Sending Unit
I should do that to the one on my W600.
good job. I just cleaned one up for mine too. the floats are the same as 60s mustang. about 6 bucks online. made by Francis drake I think
- City: puyallup,wa
Ive also had issues with mine since I got it. When tank was full gauge would read just above half. After some time the gauge quit working. I just got a float for the mustangs and now it reads half tank when it is full. The old float had a rubber ring around it. Even when I put it on new float it is still not correct.
The rubber ring is so it won't clang on the bottom or top of the tank when close to empty or full.
- powerwagon54
- City: Washougal
If it is an aftermarket sender, that is the best you will get out of it. They are junk.sledgehammer wrote: ↑Sat Nov 03, 2018 5:01 pmIve also had issues with mine since I got it. When tank was full gauge would read just above half. After some time the gauge quit working. I just got a float for the mustangs and now it reads half tank when it is full. The old float had a rubber ring around it. Even when I put it on new float it is still not correct.
Replacing a float is one thing, but certainly is nowhere near rebuilding a sender.
- City: puyallup,wa
I hear what you mean by clanging when full. I’ll put the rubber ring back on it next time I pull it back out and try to figure a way to fix it. Thanks.
