Accessory Gauges
earlymopar
City: Newberg
Accessory Gauges
Post by earlymopar »
I'm adding an accessory gauge cluster to my 65 Series I and all 3 gauges have back lighting. Where is the easiest or best location to tap into factory lighting to take advantage of the factory dimmer (without butchering the OEM wiring)?
- EM
hmaynord
City: fairhope
Re: Accessory Gauges
Post by hmaynord »
I just used one of the existing bulbs
harris
driving it since 12/03/71
earlymopar
City: Newberg
Yep, I looked at the bulbs on the instrument panel yesterday but man those are small gage wires leading to the bulb sockets.
hmaynord
City: fairhope
Post by hmaynord »
yeah, but you're just adding 3 little lights
harris
earlymopar
City: Newberg
Yes I know. The amount of draw was / is not my concern. I just don't like the fragility of small leads but I'll likely use it anyway.
- EM
earlymopar
City: Newberg
Too bad a fuse tap wouldn't work as that would be a much "cleaner" solution. But that wouldn't allow the dimmer control to the lights in the new gauges.
- EM
coelcanth
City: Brooklyn
State: NY
Post by coelcanth »
i think i took apart the plug from the back of the headlight switch and found the main feed for the dash lights..
then i either piggybacked on that slot or crimped two wires (the original and the new) into the flat blade connector to run a second feed for the new lights
hmaynord
City: fairhope
Post by hmaynord »
I'll bet both the wire coming out of the switch and going to the dash lights, as well as the wire ending up at the bulb, are 18-20.
when I did the rewire job, I concluded that, based upon research and trial and error, the best functional way to splice into any wire was to use an uninsulated step-down butt connector with crimp and dual-layer heat shrink, like this:
https://www.dropbox.com/s/fft2wmgpcj5g7 ... 9.jpg?dl=0
that step-down connector is a 16-14 to 22-18. 1 wire into the red side and 2 into the blue side.
you may not like the looks of it, but it's never coming apart and it's sealed to prevent corrosion.
by splicing into the wire going to the bulb, you accomplish your goal of doing the least damage to the oem wiring.
harris
