stock fender mounted turn signals Q
I have a 66 D300 with stock fender mounted turn signals like I have seen on 400 and up series. the buckets themselves are not stock (been broken and replaced long ago) but I can tell the set up is original because the grill lights are single filament and cant act as turn signals. Does anyone have a pic or model number of the correct turn signals assemblies?
Re: stock fender mounted turn signals Q
I switched the fender mounted lights on my 70 D500 for Signal Stat using 1157 style bulb giving me turn signal and park lights. If you want to convert the grille mounted ones to park/turn signal light you will need the assembly's from a 100/200 series.
