Reverse lights not working
Posted: Sat Sep 24, 2016 8:23 am
by 71swept777
Hey there,
Have a 71 Dodge D100. When purchased it had the 3 on the tree removed and a 3 speed on the floor put in. I fixed the speedometer not working issue, but don't have reverse lights. Is there something "buried" in the steering column that needs to be jury rigged - or? Thanks in advance.
Re: Reverse lights not working
Posted: Sat Sep 24, 2016 9:54 am
by PwrWgnDrvr
The reverse light switch is usually on the transmission, not the column.
Posted: Sat Sep 24, 2016 2:25 pm
by 71swept777
Right. So I need to find those reverse wires and wire them to the reverse switch on the new trans?
Posted: Sat Sep 24, 2016 4:08 pm
by 712edf
Yes. And its possible that the previous owner removed those wires or just didn't plug them back in. I'm assuming only the shifter was changed & the truck still has same transmission, correct?
Posted: Sat Sep 24, 2016 4:33 pm
by 71swept777
Correct - original trans. I will take a look - thanks!
Posted: Thu Sep 29, 2016 8:39 pm
by marklein
It's the 2 outer wires on the neutral safety switch. One has 12 volts+, the other goes to tye backup lights. The center wire is the neutral safety.
Posted: Tue Mar 07, 2017 12:44 pm
by Caliswept
saw this post and its right up my alley....
my neutral safety switch has 3 prongs also
1 Is reverse lights and now work...
I reversed traced the wires and found out that 1 black wire is not connected... I cant figure out where it goes to...
so if anyone has retraced them back, can u please let me know...
Posted: Tue Mar 07, 2017 12:47 pm
by Caliswept
where does the center one go connected if u trace it back to the wiring harness?
Posted: Thu Mar 09, 2017 4:57 pm
by pwadventurer
Caliswept wrote:where does the center one go connected if u trace it back to the wiring harness?
My guess would be starter relay, ground wire
Posted: Thu Mar 09, 2017 8:42 pm
by MadMC63
I think a good question to ask is will it start in gear?
