Reverse lights not working
- 71swept777
- City: Hudson
- State: WI
Hey there,
Have a 71 Dodge D100. When purchased it had the 3 on the tree removed and a 3 speed on the floor put in. I fixed the speedometer not working issue, but don't have reverse lights. Is there something "buried" in the steering column that needs to be jury rigged - or? Thanks in advance.
WASH YOUR HANDS. Work hard & BE NICE TO PEOPLE.
Re: Reverse lights not working
The reverse light switch is usually on the transmission, not the column.
- 71swept777
- City: Hudson
- State: WI
Right. So I need to find those reverse wires and wire them to the reverse switch on the new trans?
Yes. And its possible that the previous owner removed those wires or just didn't plug them back in. I'm assuming only the shifter was changed & the truck still has same transmission, correct?
- 71swept777
- City: Hudson
- State: WI
Correct - original trans. I will take a look - thanks!
- marklein
- City: Red Deer
It's the 2 outer wires on the neutral safety switch. One has 12 volts+, the other goes to tye backup lights. The center wire is the neutral safety.
- City: Winchester
saw this post and its right up my alley....
my neutral safety switch has 3 prongs also
1 Is reverse lights and now work...
I reversed traced the wires and found out that 1 black wire is not connected... I cant figure out where it goes to...
so if anyone has retraced them back, can u please let me know...
- City: Winchester
where does the center one go connected if u trace it back to the wiring harness?
- pwadventurer
My guess would be starter relay, ground wireCaliswept wrote:where does the center one go connected if u trace it back to the wiring harness?
I think a good question to ask is will it start in gear?
1971 Dodge D100
