Factory wiper wiring
crawlerdan
City: auburn
Post by crawlerdan »
I removed my factory harness and did what I should have with it, trash can!
I've made a new harness, truck is driving well, all that is left is wipers, i want to use a standard on off switch, i don't care about high and low, just want on and off. Any on know which wire's are ground, and which one is power? Thanks!!
Re: Factory wiper wiring
Why did you toss wiper harness. Switched key on Power to stock wiper witch and hook up to wiper motor with stock harness and it will work correctly. How hard would that have been.
crawlerdan
City: auburn
Because there wasn't a wire in the truck that was safe to use. Not my first rodeo partner. Wouldn't have done it if it wasn't necessary.
So now I have a new switch, just need to know what color wires on the motor do what
pwadventurer
Post by pwadventurer »
Light blue is power to switch, dark blue is constant power to motor (for reversing). Brown is low (through external resistor), red is high. Green is reverse "wiper park position" (through internal park position switch) in motor housing. Green and brown make in off position for low speed park. motor is grounded through frame.
If your using a toggle witch. you will have to keep bumping switch till wipers get to the park position.
crawlerdan
City: auburn
pwadventurer wrote:Light blue is power to switch, dark blue is constant power to motor (for reversing). Brown is low (through resistor), red is high. Green is reverse "wiper park position" (through internal park position switch) in motor housing. Green and brown make in off position for low speed park.
thank you very much, i appreciate it
pwadventurer
No problem, good luck.
