No brake lights
No brake lights
Hello, 68 w200 with a steering column out of a van or rv or something. Taillights, blinkers, and hazards work but no brake lights. Pedal switch good, took apart steering wheel and turn switch, don't see the problem. Any insight?
68 W200 440 flatbed.
Re: No brake lights
Looks like brass contact buttons are worn down and not making contact with W-shaped wire. Gonna jump them and see what happens.
Re: No brake lights
I jumped the w-shaped wire to the brass contact buttons and got the brake lights to work! At least now I know I just need a new blinker switch assembly. Couldn't have done it without the wiring diagrams and other threads on this forum, thanks!
Re: No brake lights
good work!
Re: No brake lights
New switch came today. Installed and brake lights worked but no turn signals. Aaaaahhhhrrrggghhh! 30 seconds later I remembered turn signals don't work with ignition off. All is good now!
Re: No brake lights
I'm not sure if this is proper or not but i will add my problem of no brake lights to this thread. 1968 D200. Everything was working fine then I realize I have no brake or tail lights, everything in front is working. I opened the dash panel to check wiring and i find three wires that are not attached to anything. Can anyone identify where these wires should go and does the lack of continuity of having them unplugged cause this problem? The wires are orange, dark blue and light green and they all have rubber boot plugs on them. I seem to have power at the brake switch and up through the column to the turn signal cam.
Thank you
Thank you
- pwadventurer
Re: No brake lights
I would venture to say since you have after market gauges, the orange, (Temp sending unit), dark blue, ( 5 volt power to temp gauge) and light green, ( right turn signal), yellow, (left turn signal). The black wire in the right turn signal spot is probably instrument lamp.
Send picture of front side gauges, id like to see what fits.
The brake lights not working can be a number of possibilities. bad grounds cab to bed or lamp housing, lamps out, fuse, brake pedal switch, turn signal switch, cut wiring, bulk head connector.
Re: No brake lights
White-no power
Red-flashes with either turn signal or solid in the neutral position
Yellow #1-comes on with the brake pedal
Yellow #2-comes on with the left turn signal
Dark green-comes on with left turn signal
light green-comes on with right turn signal
Black- comes on with the ignition
- pwadventurer
Re: No brake lights
My 68 300 did that too. Hit brake pedal dash lights came on. Replaced turn signal switch, fixed problem.
