Hazard switch
- City: reno
- State: NV
Hazard switch
Can I add a hazard light switch to my 66 w100??
- pwadventurer
Re: Hazard switch
Shouldn't be a problem. Make sure you install a fuse inline to the flasher unit.
- City: reno
- State: NV
Re: Hazard switch
Thanks man. I appreciate it.pwadventurer wrote:Shouldn't be a problem. Make sure you install a fuse inline to the flasher unit.
- City: reno
- State: NV
Re: Hazard switch
Is there any way that you could blow it up and or clear it up to a full page if you can. I tried to blow it up but it is blurry.pwadventurer wrote:Shouldn't be a problem. Make sure you install a fuse inline to the flasher unit.
- pwadventurer
Re: Hazard switch
click to enlarge,I can email or text you full size if you cant read this.
- City: reno
- State: NV
Re: Hazard switch
Thank you very much. That helps alot. Is that box with the five contacts the hazard switch itself??
- pwadventurer
Re: Hazard switch
Yes, but in one line diagram form.
- 1surfer
- City: Breckenridge
Re: Hazard switch
Do you have a diagram of what the colors of wires coming out of the turn signal switch are. I printed the larger diagram buts its blurry and I have having a difficult time picking out those individual wires.
1968 W100 4x4
2008 2500 Cummins 4x4 Crew Cab
High Rockies
High Rockies
- pwadventurer
Re: Hazard switch
Right front Turn signal switch------(light green)---------------------(splice)----------Hazard switch,
dash indicator,
Right front lamp.
Left front Turn signal switch---(Yellow/black tracer)-//-(yellow)----(splice)------Hazard switch,
dash indicator,
Left front lamp.
Right Rear Turn signal switch---(Dark Green)------------(bulk head connector)--------Hazard switch,
Right rear lamp
Left rear Turn signal switch----(Yellow)-----------------(bulk head connector)-------Hazard switch,
Left rear lamp.
dash indicator,
Right front lamp.
dash indicator,
Left front lamp.
Right rear lamp
Left rear lamp.
- City: reno
- State: NV
Re: Hazard switch
Thanks very much.
- City: reno
- State: NV
Re: Hazard switch
What year switch is that, It has 5 contacts???pwadventurer wrote:Right front Turn signal switch------(light green)---------------------(splice)----------Hazard switch,
dash indicator,
Right front lamp.
dash indicator,
Left front lamp.
Right rear lamp
Left rear lamp.
- pwadventurer
Re: Hazard switch
the hazard switch is 1970.
- oldfrogdiving
- City: melbourne
- State: FL
Re: Hazard switch
Man this circuit lay out was just what I was looking for thanks for this!
Frog
Frog
66 D200 225 uti (ex mil, gone but not forgotten)
71 W200 318 4spd limited slip 67k
89 F250 7.3 idi 61k
87 Dodge Raider 91k
96 F350 4x4 PSD 109K
89 F250 7.3 idi 61k
87 Dodge Raider 91k
