Has anybody heard of the signal Stat 900 ?
Would that be a good choice to replace my broken 2510945 signal switch ?
Signal Stat 900
- 1surfer
- City: Breckenridge
Signal Stat 900
1968 W100 4x4
2008 2500 Cummins 4x4 Crew Cab
High Rockies
High Rockies
Re: Signal Stat 900
Yes, I use one. Had to run the wires outside the steering shaft tube.
- 1surfer
Re: Signal Stat 900
Is it a good alternative ?
Brakelights signals and flashers work?
Is the horn a separate wire ?
1968 W100 4x4
High Rockies
High Rockies
- WD
- City: Rosemark
Re: Signal Stat 900
I use an ancient version in my 49 truck. Everything worked fine last time the truck was in service (1994).1surfer wrote:Is it a good alternative ?
Horn is separate.
Same system is still common in ag trucks. They work fine and seem to last forever. Except the cancel wheel wears out after about 50 years.
- 1surfer
Re: Signal Stat 900
I might have to go with the signal stat 900 and when I hit the lottery I can buy the proper switch.
1968 W100 4x4
High Rockies
High Rockies
- 1surfer
Re: Signal Stat 900
Signal stat works great. Put it in and it does the brake lights, turn signals and the flashers as promised. It is a great alternative to an expensive NOS turn signal unit.
1968 W100 4x4
High Rockies
High Rockies
- City: barrington
- State: NH
Re: Signal Stat 900
I too will be going this route. You can get them with a horn button on the very end as well. It's not the 900 model though. http://www.truckspring.com/heavy-duty-t ... SM920.aspx
Hand me my hat. Excuse me man, where's the door
