Going back to Points
A mechanic friend of mine ( who moved) replaced the original points system w/ a pertronix system a few years back when I didnt have time to deal with it. And now I wish to go back to the original parts(long story) . I have no reference now of how they were installed.
Can some one post where the original ballast resistor was located? Where does the wire go off the back of the points? Is it just to ground? Where does the black wire off the coil go?..... to any ground or to the side of the dizzy? Any pics or reference are appreciated.
- pwadventurer
Re: Going back to Points
The ballast resistor sits right above the wiring bulkhead connector. Should be a pink and red wire on one side and a red on the other side. Pink wire from ignition key start, red to positive side of coil. Other side red to ignition key run. Might be two screw holes where it originally mounted. The black wire from points goes to negative on coil.
- City: Santa Barbara
Curious as to why are were not happy with electronic ignition - was it something with the Pertronix distributor in particular?
- Cody100
- City: Inwood
Just curious, what are the benefits of the pertronix EI? Is it just more reliability and less maintenance?
Cody
1966 D-100 Custom
1966 D-100 Custom
- johnah
- City: Pompano beach
Yes and yes, easy install took me about an hour. Runs and strats betterCody100 wrote:Just curious, what are the benefits of the pertronix EI? Is it just more reliability and less maintenance?
Thanks for the help all. I really liked the way the engine ran with the Pertronix...but I toasted 2 out of 3 I owned on this project and another. The timing seemed more stable and the engine ran smoother. I may try an old mopar HEI system next when I get the time.hitparader wrote:Curious as to why are were not happy with electronic ignition - was it something with the Pertronix distributor in particular?
- City: B.C.
Chrysler style electronic boxes are junk lately too, either Chrysler or aftermarket.
Sheldon
Sheldon
runcharger wrote:Chrysler style electronic boxes are junk lately too, either Chrysler or aftermarket.
Sheldon
Good thing I have a sizable collection of original Chrysler 4 and 5 pin ignition box's.
- City: B.C.
Kim: I save every old one I find as well, much more reliable than the new store bought ones.
Sheldon
Sheldon
In the 40 yeas that I have been driving MOPARS with the factory electronic ignition, Think 2 or 3 failed in that time.
Ballasts periodically, But always carried a spare.
- jwing68
- City: Lethbridge,Alberta
A good ignition upgrade is to install the GM HEI module on your rig, it is simple and does away with the ballast resistor, mother mopars electronic ignition works well but it is not a true high energy spark which is why the spark plug gap remains the same as an antiquated point system @.035. The GM module is cheaper than mother mopars as well.
66 Fargo W100 Sweptline SWB Poly 318
67 Fargo W100 Sweptline SWB Poly 318
68 Fargo W300 dually LA 318
66 Dodge W200 Poly
65 Dodge W300 dually Poly 318
68 Pontiac Firebird 350
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
Any chance the pertronix are getting fried because of an installation error ?69W200 wrote:hitparader wrote: really liked the way the engine ran with the Pertronix...but I toasted 2 out of 3 I owned on this project and another. The timing seemed more stable
Like if you forgot to include the ballast resistor in the circuit when required ?
Just thought these were supposed to be very reliable units... Haven't had any problems with mine in about 3 different cars
I used the diagram on one and the other used a jumper to get 12v . I believe I was told they could handle 12vcoelcanth wrote:Any chance the pertronix are getting fried because of an installation error ?69W200 wrote:hitparader wrote: really liked the way the engine ran with the Pertronix...but I toasted 2 out of 3 I owned on this project and another. The timing seemed more stable
I constantly hear of failing petronix in the world of Power wagons and MVs. NOS points and NOS condensers are the way to go. if you set up points correctly with a dwell meter it will start and run as good as any electronic system. LIke you are all saying the aftermarket parts are just terrible these days. I think the accel brand points and condenser might still be good quality. the GM is not very reliable in my experience. I used to own chevies and if one plug wire would go bad it would fry the module. 120 bucks every time. and the big ugly thing looks terrible. ;/)
I have the MoPar Performance E.I. kit on all of my Sweptlines as
well as my '67 R/T. All have worked fine for years without any
issues.
issues.
- PwrWgnWalt
- City: Butte
- State: MT
Ditto what John said.... coils have given me the most issues over the years.Hobcobble wrote:I have the MoPar Performance E.I. kit on all of my Sweptlines as
issues.
Ballast Resistors come in second. Never had a problem with distributor, especially the MPP kits.
Walt
- City: Stockton
i agree with Walt and John.
my '68 W100 (LA318) had a petronix system in it when i bought it. 2nd time i drove it, after about 100 mi it started crapping out and i barely made it to the next off ramp. sat there for 45 min until it cooled down enough to start working again. had to stop and let it cool once more before i made it home. i junked the petronix system and went with the mopar performance kit (orange brain box and recurved distributor). ignition's run fine ever since.
as far as the ballast resistor concerns, in all my mopars i mount a 2nd ballast resistor right above or below the original. that way if the original goes out is quick fix to swap wires to the back-up. in all my years of driving them i can't remember ever having to swap one out tho...
- Cody100
- City: Inwood
Anyone have a link for where to pick up a MoPar Performance E.I., like John had mentioned? I checked summit and only found a distributor cap...
For the /6
For the /6
Cody
1966 D-100 Custom
1966 D-100 Custom
