So I discovered why half my instrument cluster is out - a critter's been gnawing on things up there. Apparently has a thing for the blue wires. Anyway, as I am trying to put this back together, I have some questions (pics attached for reference):
1) Strapped to the back of the speedo is a...condenser? Where was that wired to? Possibly the bus bar on the back of the ammeter?
2) There is a heavy gauge (~10awg) red wire that I can't find the other end of. You can see it in the pic above the fuel gauge. It looks like a clean cut, tho, no teeth marks. And it also looks like the PO (grandpa) already ran alternate wiring direct for the ammeter. Is it possible this is just a clipped leftover from the conversion?
3) Is it possible my truck does not have dummy lights for oil, temp, and high-beams? They are shown on the wiring diagram but seem to not exist on my instrument cluster.
Thanks
'66 Instrument Cluster questions
Grandpa's '66 W200
If it aint' broke..., I probably haven't fiddled with it.
Re: '66 Instrument Cluster questions
condenser is just for radio noise suppression. According to the radio wiring schematic I have it shows the condenser hooked to 12 v side of voltage limiter . If you want I can send you the file so you can see it. P M me your e mail addy.
- pwadventurer
It looks like the two black circles top pic, are the instrument lights, should be black wire to each. The orange circle is the high beam light, orange wire.
not sure why two pics the same posted
The bottom pic with black circle is Left turn signal lamp with yellow wire to it. It also looks like an amp bypass plate was installed.
- Attachments
- 66 instrument lights 1.png (226.64 KiB) Viewed 977 times
Thanks, all. I got it put back together, only three wires I could never figure out where they go. The gauges and indicators all work now.
So what does the ammeter bypass plate do? The ammeter still works, so..
Grandpa's '66 W200
Eliminates amp gauge . Wont register after its jumped.
That's what I would have thought. However, 1) the gauge still operates, and moves as you'd expect, and 2) grandpa installed amp gauges on everything he owned that had an engine - there's no way he survived without a properly working ammeter in this truck.
Is it possible that the needle deflection is smaller than without the bypass, but it still works?
What was the advantage of installing a bypass?
Thanks
Thanks
Grandpa's '66 W200
Possibly they added them for the camper special wiring.
- PwrWgnWalt
- City: Butte
- State: MT
Cadman, it is possible that the bypass works to eliminate full alternator/battery current from passing through the gauge. If a higher output alternator is installed, this could be a safety measure (makes sense that it could have been for Camper Specials, but I've never personally seen this before). The fact that the ammeter still works is interesting and gives credence to the safety measure idea.
Walt
Walt
