Dead fan motor?
Dead fan motor?
A few years ago, I noticed that the heater fan switch in the '61 Ute was getting a little warm. Not too long after that, it went from warm to hot, then the fan stopped working. I haven't looked at it since, mostly because I only drive the truck when the weather is nice (AKA, not when it's cold or humid), but I guess that it's probably time to fix it. Does this sound familiar to anyone? Based on the heat, it makes me think that perhaps the windings on the motor shorted out. Is there some other culprit?
Re: Dead fan motor?
I would think that if the motor shorted (heat=high amps) the fuse would pop. However, high resistance in the fan switch (like from corrosion or a bad solder joint) would cause the switch to heat up, and eventually fail and break the connection. So my 2 pennies are on a bad switch. Have you tried to jumper out the fan switch?
BB
BB
Grandpa's '66 W200
If it aint' broke..., I probably haven't fiddled with it.
Re: Dead fan motor?
That'll be on my list of troubleshooting stuff. I'm going to work on it this weekend.cadman wrote:I would think that if the motor shorted (heat=high amps) the fuse would pop. However, high resistance in the fan switch (like from corrosion or a bad solder joint) would cause the switch to heat up, and eventually fail and break the connection. So my 2 pennies are on a bad switch. Have you tried to jumper out the fan switch?
Re: Dead fan motor?
Frayed and corroded wiring was the culprit. I cleaned it up and resoldered the joint and got a nice blast of warm air.
