Brake lights...
- City: chappell
- State: NE
Brake lights...
OK..We have now got everything working on my 68 Dodge at the rear except stop lights..We replaced the stoplight switch,have power to the 1 side when brakes aren't pressed,and power in and out when stepping on brakes..But no brake lights..Have turn signals..Always thought the brke and turn were on the same filament..Any ideas...Thank You in advance...
MOPAR. Massively Over Powered And Respected
Re: Brake lights...
I had a similar problem and it was the turn signal switch.
Re: Brake lights...
I have the same problem on my '69. I have not checked the brake switch yet but I have turn signals and the fuse is good. Where is the switch? I do not see it on the m/c or the pedal lever. Did you find the source of your problem? Do you mean the turn signal switch in the column as in I have to pull the column to replace?
Thank you.
Thank you.
- Jims68
- City: Edgewater Park
- State: NJ
Re: Brake lights...
Yep.... brake lights and turn signals use the SAME filament.
Re: Brake lights...
That's where my problem was. The signal switch was worn out andturtle1 wrote: Do you mean the turn signal switch in the column as in I have to pull the column to replace?
Thank you.
producing a short. I replaced it and have had no issues since.
Re: Brake lights...
thank you,
just pull the steering wheel and should be not too hard to replace I'm guessing , unless someone chimes in and tell me otherwise.
anyone know if the '69 has the pot metal or plastic before I go fiddle with it so I can order one ahead of time?
Hobcobble wrote:That's where my problem was. The signal switch was worn out andturtle1 wrote: Do you mean the turn signal switch in the column as in I have to pull the column to replace?
Thank you.
