I have voltage at the 5v dark blue wire coming out of the fuel gauge. It fluctuates and I can't get a steady reading, as does the connection at the temp gauge. Sometimes it appears to spike as high as 25 volts (?), which is probably the meter trying to adjust. I realize the regulator normally will fluctuate when working correctly. My question: When the instrument voltage regulator goes bad does it still fluctuate and put out power like mine is doing?
I grounded the sender connections off the fuel gauge and the temp and the needles never moved.
Sean
'69 Dash Voltage Regulator , Bad or Good?
Re: '69 Dash Voltage Regulator , Bad or Good?
I'd look into the voltage limiter if I were you.... Sounds like its on its way "out"turtle1 wrote:I have voltage at the 5v dark blue wire coming out of the fuel gauge. It fluctuates and I can't get a steady reading, as does the connection at the temp gauge. Sometimes it appears to spike as high as 25 volts (?), which is probably the meter trying to adjust. I realize the regulator normally will fluctuate when working correctly. My question: When the instrument voltage regulator goes bad does it still fluctuate and put out power like mine is doing?
Sean
See this in Tech section. http://sweptline.org/forums/viewtopic.php?f=33&t=22961
