I rebuilt a turn sig. switch for my 65 D100, now, what is the easiest way to fish the wires down the column for re install??? Do I have to take the steering column out of the truck?? Any tricks to do this without removal of the steering column.
Thanks.
Fish
trun signal switch, how to feed wire down column
Re: trun signal switch, how to feed wire down column
Well, there is no way to snake a turn signal switch wiring harness down the steering column with steering shaft still in the way. I pulled the column, then tied a string to the end of the old harness so when I pulled it out, I could tie string to new harness to pull it back down through. It was a little bit of a bear even with the column out of the truck on my work bench. While out, I also put a little grease in the bearing assembly. Will finish the whole project next time in my shop. Cross your fingers all lights and blinkers work now, they should.
Fish
Fish
I've replaced 3 turn signal switches w/o removing the column shaft. Takes a little patience. Taped the ends of the lower wires together and the uppers together and pushed them down the shaft. Used a dental pick to fish them out the respective openings. .
I guess thats why they say dont mess with Texas! Your more than a man than me!
In my deffence, The new harness I installed did have a few repair splices in it making it slightly wider in spots. I know this didnt help matters. I could have never of done it with the column and shaft inside.
Fish
Fish
One nice think is it only takes 3 bolts to pull the column out. Really no big deal.
68fish wrote:I guess thats why they say dont mess with Texas! Your more than a man than me!
Fish
