Voltage Regulator keeps Frying!
Postby JunkHead » Wed Dec 17, 2014 10:29 pm
Here the issue...I have blown 3 Voltage regulators in the past 3 months. I first replace the original Regulator about 6 months ago just to have it new. I blew the first voltage regulator 3 months ago. Fortunately i had it warrantied and drove it for about 3 months till about a couple of days ago i blew another one. At first i found out my heater fuse was too big and it MAYBE it could have been shorting or arcing and making it past the fuse box to cause this issue. Once i took the heater fuse completely out i decided to put my original 1966 voltage regulator back in the truck...(which still worked) i drove for maybe 10 blocks when i noticed it was not charging anymore. What Do You Guys Might Think The Issue Is>..??????? truck has a new alternator, starter and relay. When the regulators fry i can still drive the truck for more than a couple of days.
-What i have done so far is replaced some of the wiring harness and checked for possible short circuits. I did notice that my fuse box looks pretty rough on the back side, but i have gone through all the fuses and cleaned the terminals. Does anyone know where i might be able to find a 1966 dodge d200 replacement fuse box?
Thanks for your time!!!!!!---JunkHead :thinking :usa
JunkHead
City: San mateo
Re: Voltage Regulator keeps Frying!
Postby dodgeboykim » Thu Dec 18, 2014 11:22 pm
powerwagon54 possibly.
Postby halliejean » Sat Jan 24, 2015 11:41 am
Having the same issues; not sure what to do. I'm on volt/reg#4... tried grounding out & still keeps burning up. Have you had any luck coming up with a solution??? :salut
halliejean
City: Citrus Heights
Postby dodgeboykim » Sat Jan 24, 2015 2:28 pm
And for me in 40 years of owning Swepty style trucks I have never had recurring voltage regulator problems. I have replaced the odd reg or alt/brush's but that's it :Thumbsup .
Postby jwing68 » Sun Jan 25, 2015 5:11 pm
I would back pedal a bit and take a look at what was replaced, is your new alternator functioning correctly ? Have it bench tested to confirm, sounds like maybe a diode issue. Is the regulator confirmed to be grounded correctly ? Did you run any AVR checks after the parts were replaced ? Have a battery that is fully charged when you fire up your new charging equipment otherwise it can charge at a rate that can damage rebuilt alternators and the inferior stock wiring these trucks were built with. :2cents
67 Fargo W100 Sweptline SWB Poly 318
68 Fargo W300 dually LA 318
65 Dodge W200 Poly
63 Dodge W300 dually Poly 318
68 Pontiac Firebird 350
2005 HD FXST Custom
jwing68
City: Lethbridge,Alberta
Postby halliejean » Fri Jan 22, 2016 9:13 am
installed solid state regulator from a '75 D-100. Have ECU and re.man distributor; schematic got wet & trying to find previous link for wiring diagram. . .
halliejean
Postby dodgeboykim » Fri Jan 22, 2016 1:51 pm
halliejean wrote:installed solid state regulator from a '75 D-100. Have ECU and re.man distributor; schematic got wet & trying to find previous link for wiring diagram. . .
Did you use the dual field alternator with that volt regulator. :thinking
66 W100. 70 D 500 with 69 Hiab Speed Loader. 96 Ram 3500 Club Cab Cummin's 5 spd. 97 Ram 1500 Club Cab 5.9 gas auto. 83 W200 L/B 360 auto on propane.
Postby RobertGilliam » Tue Feb 16, 2016 10:50 am
Most alternator shops will convert it to a one wire for 45/50 bucks. Eliminates a lot of issues.
RobertGilliam
City: Clinton
Postby LuckyBaldwin » Fri Jul 08, 2016 1:05 pm
had the same problem when i first bought my '68 W100. went through 3 new regulators in 3 days. the only points style regulators you can get now are made in china and are pure cheese. took each of the 3 regulators apart after they failed and was the points each time. the two contacts aren't parallel. the moving contact hits the stationary one at a 20 to 30 degree angle so that only about 10% of the contact surface area was carrying the full electrical load. is it any wonder they burn up in a day?
i fixed the problem by installing an airtex/wells electronic regulator, p/n: 1V1067
http://www.airtexve.com/custom_searches ... 7#zoom=100
is a single field, plug and play swap with no modifications needed. has charged fine ever since. the instructions said to make sure the regulator is grounded to the body before connecting the wires.
http://www.airtexve.com/custom_searches ... 700268.pdf
LuckyBaldwin
City: Stockton
Postby longbed67 » Sun Jun 11, 2017 8:05 am
just changed mine over to gm style one wire. took out the ammeter added a voltmeter. system works great now
longbed67
City: woodlands
Return to *ELECTRICAL SYSTEM HELP*
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
